How or can I create a link to report local control of the relay back to homeseer?
2450 I/O link Local control
can you describe your setup of the iolinc?
typically the relay is output which is controlled by hs so you would know the status already. But you can poll the device so hs will get the latest status. I don't recall if the iolinc even sends a msg when the relay changes status. I don't think it does.Mark
HS3 Pro 4.2.19.5
It is pretty much standard out of the box, continous on/off with no other responder or controller links beyond those created using the "Program Device for HomeSeer" button.
I did set the poll interval to 1 min in order to see any change in status by local control. It would just be nice if it was able to see it via link.
Originally posted by mnsandler View Postcan you describe your setup of the iolinc?
and what you are controlling with the iolinc? are you using the input sensor as well?Mark
HS3 Pro 4.2.19.5
Here's the issue which is related to the fw of the device:
the output relay sends on & off msgs when you press the set button. However the input sensor sends the exact same on & off msgs. so there is no way for me to know which unit (relay or sensor) sent the message.
So i defaulted to decoding the msgs as being sent from the input sensor since this is what most people need.Mark
HS3 Pro 4.2.19.5
Just to better understand why I was asking.
This unit actually is controling my water softener so I was trying to get HomeSeer to see the button push and start a regen cycle (for at the unit maintenance purposes). With the poll set at one min it just takes a little bit for HomeSeer to see the change and run the script.
Thanks again,
Jim
Originally posted by ramblreb View PostJust to better understand why I was asking.
Thanks again,
JimMark
HS3 Pro 4.2.19.5
Originally posted by ramblreb View PostOne more question, if the message sent is the same for the input and the local switch why dosen't the input say it came on when the button is pushed?Mark
HS3 Pro 4.2.19.5
OK but you said
"the output relay sends on & off msgs when you press the set button. However the input sensor sends the exact same on & off msgs. so there is no way for me to know which unit (relay or sensor) sent the message. So i defaulted to decoding the msgs as being sent from the input sensor..."
If that is true then wouldn't pressing the set button cause HomeSeer to say the input changed states?
