On the Insteon Device Edit Links page, when you define a new link, sometimes you are presented with the option "Cross-Link Devices?" What does this mean?
Cross-Link Devices?
if the responder can also be a controller, and you want a bi-directional link (ie cross-link), the plugin will link the responder back to the controller as well.
this is useful for creating a 3-way circuit for example, where either switch can control the load.Last edited by mnsandler; March 16, 2016, 02:35 PM. Reason: hover over the little Blue question mark (?) to get a short explanationMark
HS3 Pro 4.2.19.5
Originally posted by JimSpy View PostAre KeyPadLinc buttons considered "responders", i.e., they light up in "response" to a signal from a controller?Mark
HS3 Pro 4.2.19.5
I have several Outdoor ApplianceLinc devices. At some point I was able to cross-link with them. This is no longer available when selecting a ApplianceLinc when editing links.
Example Outdoor ApplianceLinc link with a working link:This works great because when the button is pressed or controlled by the WebUI the Keypad is also updated.Link #4 Outlet controls Living Room Keypad Button G (1C.8E.D2) Link #3 Outlet is controlled by Living Room Keypad Button G (1C.8E.D2) - On Level : On Link #1 Outlet is controlled by HomeSeer using Hub Group #0 (i2CS Registration Link) - On Level : Off Link #2 Outlet is controlled by HomeSeer using Hub Group #254 (HomeSeer All Devices Group) - On Level : On
Can we have this feature back for Outdoor ApplianceLinc devices as they seem to support being a controller just fine.
Jason
Originally posted by jrhubott View PostI have several Outdoor ApplianceLinc devices. At some point I was able to cross-link with them. This is no longer available when selecting a ApplianceLinc when editing links.
Jason
can you tell me the devicetype code of the device you are referring to? Check the insteon.ini/.
also what version of the plugin are you running? this should work in the latest betaMark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Post
jason
Device type: 0206
It works on the device type: 0238 (Dual-Band Outdoor Module) just not on the 0206(Outdoor ApplianceLinc). At one point in time, several years ago it worked on the 0206 as
i posted 3.0.6.40 to the beta section. this should allow you to create controller links from the Outdoor Applinc). please test and report backMark
HS3 Pro 4.2.19.5
Originally posted by jrhubott View PostWorks great. Thanks!!!Mark
HS3 Pro 4.2.19.5
