Originally posted by waynehead99
View Post
Discussions related to HomeSeer Beta 3.0.0.332->356
Originally posted by concordseer View PostI'm assuming that anyone testing this beta is disabling and uninstalling the HSTouch plugin before they upgrade as per the information above as their is no longer any need for it.
I'm running this beta under Raspbian Jessie and Mono 4x and experienced no real problems so far.
I'm guessing most of the problems are arising using Windows OS.
Originally posted by rjhThis version has moved the HSTouch Server plugin functionality into HS3, so the plugin is no longer used and will not be loaded (even if the file exists).HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
[QUOTE=rprade;1313760]We are disabling it and removing now, though the information above was ambiguous as to whether we should disable and delete the HSTouch plugin
Again this is just my own interpretation from the OP. The plugin functionality is gone so why leave it installed.
I'm only using 3 plugins on my system and all 3 are functioning fine. I know it's a lot more hassle for Windows users to upgrade/downgrade when problems arise testing.
The HSTouch client is definitely operating a lot more efficiently for me with this beta.
Originally posted by concordseer View PostOriginally posted by rprade View PostWe are disabling it and removing now, though the information above was ambiguous as to whether we should disable and delete the HSTouch plugin
The HSTouch client is definitely operating a lot more efficiently for me with this beta.Last edited by randy; July 4, 2017, 09:47 PM.HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
Originally posted by rprade View PostNevertheless, I would be curious if Linux users are seeing their HSTouch clients get real time status updates.
I am using Windows and Android clients, not IOS.stefxx
Originally posted by stefxx View PostIt works for me on Linux.
Restarting the clients did not work. Only after a restart of HS3 it started to work again.stefxx
Curious if there is a debug enabler for the HSTouch piece of Homeseer main?- Pete
Loaded .333 and everything seems to be working fine in Windows 10. The only problem I see is with the Honeywell Wi-fi Thermostat plug-in, where I get this on startup:
Initializing plug-in(2): Honeywell WiFi Thermostat Instance::Could not load file or assembly 'Newtonsoft.Json, Version=7.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)STACK: Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
48 hours later and it's a thumbs up for HS3 beta .334. Tested 5 different cameras on the HSTouch client. Very little lagging and delay on the images.
As far as I am concerned I've one less plugin to worry about on HS3. The more users that jump on board with the beta testing the quicker the guys at Homeseer can get a final version out there.
I'll leave .334 working away and report back any hiccups if they arise.
We now use that DLL in HS3 and we install it in the Bin folder. The plugin you are referring to appears to be using that DLL also, but a different version. The plugin author should be installing that DLL in their own bin folder, and I am guessing they are not. I will contact them to let them know.
Originally posted by prnorton View PostLoaded .333 and everything seems to be working fine in Windows 10. The only problem I see is with the Honeywell Wi-fi Thermostat plug-in, where I get this on startup:
Originally posted by rjh View PostWe now use that DLL in HS3 and we install it in the Bin folder. The plugin you are referring to appears to be using that DLL also, but a different version. The plugin author should be installing that DLL in their own bin folder, and I am guessing they are not. I will contact them to let them know.
I have fixed the Sonos issue. It appears that since the HSTouch stuff is now in HS and not using the plugin API that some passed data is a little different.
I am still baffled on the plugin startup errors though. I took a fresh install of 318, installed some of the plugins from your list, enabled them, then installed 333 of HS and all was fine.
Did you try removing the old HSTouch plugin before starting up? In the next update I will have HS delete that file, it may be causing some issues as HS will load a part of it on startup.
Originally posted by rprade View PostThis is a little frustrating and time consuming. I installed .333 over my restored .318 and once again got the error:
[ATTACH]62064[/ATTACH]
And the majority of my plug-ins failing to load:
[ATTACH]62065[/ATTACH]
Then I tried to reinstall on top of .318 with the plug-ins all disabled. Once again the update removed the licensing from HS3 as well as all of my plug-ins.
As a second attempt I copied the backup I made of the reinstalled .332 from Saturday, then put in the scheduler.dll and HS3.exe from .333 in that installation. Still so Sonos spoken events and the HSTouch default project will control devices, but not reflect the changed status. No cameras are shown in the default project.
As a third attempt I copied the 4 new files into my working.318 installation and it still generated the above errors.
Sonos plug-in uses its own speech proxy, but I would have to ask Dirk how it works.
I reinstalled my .318 backup and everything works again.
I will try to take the time to get a debug log from .332 or .333 later.
I posted an update, version 3.0.0.335 with some fixes, not sure if it fixes all reported issues, but post what you see.
If you see a plugin loading with a Newtonsoft dll error, you can fix this yourself for now. If the plugin has a config.exe file (like HSPI_JowiHue.exe.config), edit that file and make sure "bin" is at the end of the path. For the JowiHue plugin the binpath line needs to be this:
Code:<probing privatePath="bin/JowiHue;bin"/>
Originally posted by rjh View PostI have fixed the Sonos issue. It appears that since the HSTouch stuff is now in HS and not using the plugin API that some passed data is a little different.
I did not initially remove the HSTouch application when I updated my production machine from .318 to .332 or later to .333.
I built a fresh VM, copied HS3 v318 over to that machine, deleted the HSTouch executable, then installed the .333 update. I got the same Phase 3 exception error, but all of the plug-ins started.
Jul-05 12:25:39 PM Startup HStouch server started, waiting for clients to connect.
Jul-05 12:25:39 PM Error Initializing plug-ins Phase 3 Exception: Object reference not set to an instance of an object.
Jul-05 12:25:39 PM Plug-In Finished initializing plug-in UltraECM3
Jul-05 12:25:31 PM Z-Wave Starting Z-Wave Polling for Network 003D3410...
It may or may not have been the HSTouch application that caused my plug-ins to fail to start on my production machine, but they did not fail on this test. There is really no way for me to repeat the test without removing the HSTouch application, so we will just have to believe it was at the root of my plug-ins not starting. As expected Sonos still does not work. HSTouch (once configured for the IP of the test machine) still controls any device but does not return status updates to the HSTouch client.HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
Can you try your same test with build 335 and see if there is any change? I know the Sonos issue is fixed. I did make a change in regards to status updates so I'd like to see if that change helped.
