Old May 21st, 2018, 02:51 AM
Rick Bonari Rick Bonari is offline
Port Forwarding Homeseer Device Utility Page?
How do you port forward the device utility page? I forwarded the IP Address and port 80 for beginning and ending address. Still does not work? Thanks much !!!! Rick
Old May 21st, 2018, 05:51 AM
rmiles7721's Avatar
rmiles7721 rmiles7721 is offline
Can't really answer that without knowing what sort of router you have, also bear in mind that some ISPs block port 80.
Old May 21st, 2018, 06:13 AM
IanIreland's Avatar
IanIreland IanIreland is offline
You can use this; http://canyouseeme.org/ to check if your ISP is blocking the port.
Old May 21st, 2018, 08:06 AM
jeubanks jeubanks is offline
Why not just use MyHS? Much more secure than opening a FW port. If there's some other NEED that MyHS doesn't provide then use a VPN tunnel.
Port Forwarding Homeseer Device Utility Page? Rick Bonari HomeSeer General Discussion Area 1 May 2nd, 2018 08:52 AM
Device Utility Page Cannot Be Accessed cowinger HS3 / HS3PRO Discussion 0 February 10th, 2018 03:42 PM
changed port in setup -can't open device utility - HELP cowinger HS3 / HS3PRO Discussion 2 November 22nd, 2017 02:24 PM
Jon00 Device Grouping Utility (web page) for Homeseer 3 jon00 Jon00's plugins and scripts 115 October 27th, 2017 11:20 AM
Port Forwarding...Can homeseer and a DVR exsist on same network? Automate_It HomeSeer General Discussion Area 2 August 18th, 2008 08:47 PM
