Sorry if this is too basic of a question but what is the recommended way to set double and triple tap for HomeSeer dimmer switch (HS-WD100+ Z-Wave Plus)?
I spent time going through instructions shipped with the device and looking at the message board and still not clear.
I'd like:
- 2-tap to put load at 100% (max light brightness)
- 3-tap to turn on 3 different existing scenes
ISSUE? The printed instructions that come with the switch mention that the switch creates *3* devices (root, central scene, control). I get only 2; the root device is missing (or at least is not listed/grouped together with the other two... maybe the root is one of the generically labeled "Sigma" nodes I see in my list?)
NOTE! If it makes any difference, the way I am installing these new HomeSeer dimmers is by using the "replace node" button to swap some old Intermatic dimmers that fail to operate my new LED bulbs.
BTW, the GREAT NEWS is that as far as I can tell, the node replacement function seems to work, even though I am replacing an old Intermatic with the new feature-rich HomeSeer!
I'd like:
