HAI Plugin Beta v3.0.1.23
    #16
    An FYI Rob....
    Installed plugin on new Linux (Pine64 2Gb / Ubuntu 16.04 64bit) box with Homeseer 3 Pro on it.
    Right now the compuer is wan connected to the OP2 panel and will be on premise next week.
    Plugin installation was fine and it is working fine.
    Looking over the directories in Homeseer it created a homeseer subdirectory under the homeseer root directory with hai bin and html subdirectories.
    It also indicates a DCM error as on my set up to my panel. The variable DCM stays this way. I have seen the error variable go away for a day or so then come back.
    See picture.
    Not been paying attention.
    Went to production computer running the plugin and do not see that it did that when upgrading to v.23 of the plugin.
    Note too that this computer has a non Homeseer plugin running for the Smarthings hub such that the Smarthings hub has an interface connection to the OP2 such that the OP2 has multiple IP connectivity (HAI Omnitouch 7 screen is also connected).
    No IP drops that I can see with the WAN and LAN connections.
    IE: so you can do OP2 Z-Wave / Smarthings Z-Wave direct and indirect / OP2 Zigbee / Smarthings Zigbee direct and indirectly. Note here personally not a cloud person but am playing with Amazon Echo, Smarthings and other cloud connected hubs these days (for tinkering purposes).
    Dunno why.
    [ATTACH]60625[/ATTACH]
    Auto mator
      #17
      New version posted today:
      https://forums.homeseer.com/showthread.php?t=188485
      HS4Pro on a Raspberry Pi4
      HSTouch Clients: 1 Android
