Originally posted by swanie2000
View Post
Feature Requests for the Mark Sandler Insteon PLM Plug-In
Mark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Posti've got something working. anyone care to give it a test this weekend? I can post something later this week after i test a little more
Sent from my SAMSUNG-SM-N910A using Tapatalk
Originally posted by dzee View PostMark, I have a kepadlinc that needs to be reprogrammed. I'd like to test it out.
http://board.homeseer.com/showthread.php?p=1193343
please submit feedback on that thread, not this one.Mark
HS3 Pro 4.2.19.5
Mark,
Is load sense supported for 2663-222 On/Off Outlet in the plugin?
I have several and they are working great, but wanted to use the load sensing and cant seem to find anything in events or links.
I do see there is Operating Flags to turn on and off Load Sense for upper and lower, but didn't know if you had added the functionality to use it.
Let me know
Steven G
Let me know
Steven GMark
HS3 Pro 4.2.19.5
It only creates the On/Off for devices
What do I look for in events to lets say:
Example:
Upper plug has tv plugged in so it has power all the time but I want to know when a load is on so I can also turn on stereo
Steven G
so you should be able to use the hs device value change trigger
not sure if the insteon special triggers will capture thisMark
HS3 Pro 4.2.19.5
The device does not change because its always on. Wanted to use the load sensing to see if what is plugged in was on or off
These are suppose to work just like a Synchrolinc with the ability to also control the plugs on/off.
Is this something you can look into?
Steven G
i tested the plugin support with a simple (on/off) lamp and the hs device tracked the status.
i'm not sure if this device is going to do what you want.
there are no other settings/features to this device.
I'm sort of in the same boat with my receiver.Mark
HS3 Pro 4.2.19.5
Power On the Outlet and you turned the lamp off and On manually and that changed a status?
I don't see any change other than outlet is On/Off.
When I bought these I was told it was an outlet with the SynchroLinc capabilities so that's a bummer. Even says on the website
LoadSense
With LoadSense technology, your On/Off Outlet can detect when you turn on a connected lamp or appliance and automatically turn on other Insteon devices throughout your home; your table lamp just became an Insteon switch.
Thanks again for taking the time to check it out let me know about the status or if you find anything else
Steven
Originally posted by steveng View PostSo how did you see the status that may be something I can work with.
Yes, the hs device status will change on & off as you turn the connected load on & off.
can you test your oulet unit with a lamp with a 25w bulbMark
HS3 Pro 4.2.19.5
Mark,
I tried 2 different outlets (both upper and lower) turned on outlet via homeseer/manual
and pluged in a lamp
Turned lamp on and off several times and status of plug always remained On
Maybe I am doing something wrong, but cant seem to get it to work.
Any ideals
UPDATE:
I did get it to auto turn on based on turning lamp on, but turning lamp off still leaves the outlet on
Also I noticed the Upper Load Sense/Lower Load Sense get turned off randomly and I have to turn them back on and program Op Flags
Steven GLast edited by steveng; September 9, 2015, 09:53 AM.
Steven,
can you tell me the fw version of the unit? its listed on the device page within the plugin
i want to make sure i have a similar unit before i test on my endMark
HS3 Pro 4.2.19.5
All mine are Firmware Version: 44
Steven Giles
i just tested by fw 44 unit and got the same results: the led status will go from red to green but not back to red when you turn off the load manually. Strange i thought this worked on my beta unit but i just retested it and it doesn't work there either.
I have an email into Smarthome on thisMark
HS3 Pro 4.2.19.5
