This is a version 1.0.2.5 of the ISY Insteon Plug-in.
This is being released as an installation package that will update an existing installation of the plug-in to this version. It will re-use the your existing license key.
This version fixes a bug in 1.0.2.4 that would cause program commands to fail because a send lock get's stuck after a command send timeout.
This release has been tested to work with the latest ISY firmware - 2.8.2.
Installation
1. Download the ISYInsteion-1.0.2.5.zip file
2. Unzip the contents
3. shutdown HomeSeer
4. Run HomeSeerPluginISYInsteon_1_0_0.msi
5. Restart HomeSeer
Updates since 1.0.2.3
- Changes to the network communication layer to provide better error reporting.
- Changes to the network communication layer to provide better synchronization between device and program commands.
- Updated the device lists so that the latest Smarthome devices should now be recognized.
Updates since 1.0.2.4
- Fixed bug that would prevent the plug-in from sending program commands to the ISY.
Installation
5. Restart HomeSeer
