Need help reset
    Need help reset
    I mistakenly while trying to change display properties selected laptop display now when system boots up, I can no longer see display on my monitor. What can I do can?
    Any F-Key to select ?
    Remove internal battery?
    What hardware is this in reference to?
      HomeTroller-S3
      HomeTroller-S3
        Try booting in safe mode if you can. This may go to the default display. Hold F8 on booting.
          Thank you that worked
          I still have trouble with display ran updates that did not help
          Screen resolution: 640 by 480 pixel
          Low Color quality: 8 bit
          If I change setting at all I loose signal to monitor.
            Re: Need help reset
            Try to remote VNC into the hometroller. From there you can adjust/fix your display settings.
            Sent from my ASUS Transformer Pad TF700T using Tapatalk HD
              If you just purchased this unit you get 30 days free support using the blue support link above. Create a new help desk account and use report a bug as the link.
