Error Msg, "Group Cleanup"?
    Can someone please translate:
    Device Laundry Room Motion Sensor (14.98.56) sent a group cleanup report. 1 devices didn't respond. 01 14 98 56 11 03 01 CF 06 01
    This happens consistently every time the MS is triggered on or off.
    Jim Speiser
    38-year veteran of Home Automation
    Still don't know squat
    does the motion sensor control another device directly via a link
    Mark
    HS3 Pro 4.2.19.5
      Here are all the links:
      Link #2 Occupancy Sensor controls Laundry Room Fluorescents (23.DD.A8)
      Link #6 Battery Level has local control reporting to HomeSeer
      Link #3 Dusk/Dawn Sensor has local control reporting to HomeSeer
      Link #4 Low Battery Warning has local control reporting to HomeSeer
      Link #5 Occupancy Sensor has local control reporting to HomeSeer
      Link #1 Occupancy Sensor is controlled by HomeSeer using RF PLM Group #0 (i2CS Registration Link) - On Level : 1?
      Jim Speiser
        Did I say something wrong? Is it my breath?
        Jim Speiser
          i thought i responded but now i don't see it...
          looks like the MS is controlling the laundry room lights. Do the lights respond on motion?
          please enable detailed logging in the plugin and then trigger the original message and post a log snippet
          Mark
          HS3 Pro 4.2.19.5
            Yes, they respond on motion just fine, but then the MS begins flashing its LED.
            Here is what I gleaned from the log:
            Jun-01 5:41:16 PM Insteon Received STX 0x50 (Raw Insteon Rec):14 98 56 00 00 01 CF 11 01
            Jun-01 5:41:16 PM Insteon Received 14.98.56:1 (Laundry Room Motion Sensor - Occupancy Sensor) Go ON
            Jun-01 5:41:16 PM Insteon ProcessGroupBroadcast: Device Laundry Room Motion Sensor (14.98.56) is group broadcast source (tgt group/button:1) sending cmd 11
            Jun-01 5:41:16 PM Insteon Setting status and value for device 14.98.56:1. Old status:0 Old Value:0, New Status:2 New Value:100
            Jun-01 5:41:16 PM Insteon ProcessGroupBroadcastUpdateResponders: Located remote link record match for group broadcast - Device:23.DD.A8 link record #1 target channel 1
            Jun-01 5:41:16 PM Insteon Setting status and value for device 23.DD.A8:1. Old status:0 Old Value:0, New Status:2 New Value:100
            Jun-01 5:41:16 PM Insteon Received STX 0x50 (Raw Insteon Rec):14 98 56 00 00 01 CF 11 01 Debouncing repeat.
            Jun-01 5:41:18 PM Insteon Received STX 0x50 (Raw Insteon Rec):14 98 56 3D 98 D6 4A 11 01
            Jun-01 5:41:36 PM Insteon Received STX 0x50 (Raw Insteon Rec):14 98 56 11 03 01 CF 06 01
            Jun-01 5:41:36 PM Insteon Device Laundry Room Motion Sensor (14.98.56) sent a group cleanup report. 1 devices didn't respond. 01 14 98 56 11 03 01 CF 06 01
            Jun-01 5:41:36 PM Insteon Received STX 0x50 (Raw Insteon Rec):14 98 56 11 03 01 CF 06 01 Debouncing repeat.
            Jim Speiser
              might be worth a factory reset and reprogram device (from plugin) on the 23.DD.A8 device. its not sending its group cleanup responses based on the log.
              Mark
              HS3 Pro 4.2.19.5
                OK, I won't ask what a group cleanup response is, but I will try what you suggest. Thanks.
                Jim Speiser
                  Jim, the group cleanup report tells the controller device and hs interface if any of the responders didn't respond to a group command. Not really much you can do with this information.
                  Mark
                  HS3 Pro 4.2.19.5
                    Finally got this done. Didn't really have an effect, but I got bigger fish to fry. Thanks for the help.
                    Jim Speiser
