Hi, I have recently purchased the owl 119 device and brought a new rfxcom reciever and most seems to be working without issues, the power usage and power total devices within homeseer are updating and seem to be correct.
I have just installed the latest RFXCharts software (V1.1.0.10), and allowed all updates to take place.
I have enabled the operating mode and Cent-A-Meter recording but when i click on the "Cent-A-Meter" config button none of the three "Select channel 1,2,3 input device" drop downs have my Owl device listed ?
I've noticed as soon as i click on any one of the three "input device" dropdown boxes and release the mouse button the following error occurs in IE on the bottom left of the window :
Line : 79
Char : 1
error : object expected
code: 0
URL : http://localhost/RFXCharts/SetupW.aspx
If i manually edit the RFX_Charts.ini file and put my input device code in, for example :
Ch1Dc=^3
where ^3 is my input device code it seems to chart but as soon as i move around the configuration options it dies with the following :
Server Error in '/' Application
'DdlCentaDc1' has a SelectedValue which is invalid because it does not exist in the list of items.
Parameter name: value
[ArgumentOutOfRangeException: 'DdlCentaDc1' has a SelectedValue which is invalid because it does not exist in the list of items.
Parameter name: value]
System.Web.UI.WebControls.ListControl.set_SelectedValue(Stri ng value) +304
SetupW.Page_PreRender(Object sender, EventArgs e) +23373
System.Web.UI.Control.OnPreRender(EventArgs e) +80
System.Web.UI.Control.PreRenderRecursiveInternal() +88
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +5676
Any help would be greatly appreciated!
Cheers,
Mike
Line : 79
Char : 1
code: 0
Ch1Dc=^3
Cheers,
Mike
