Totally Secure Interface For Foscam H.264 IP Cameras With Or Without HTTPS
    Note: Some images are small in some of the live IP Camera demonstrations. They can be any sizes.
    Complete List With Links To All Live IP Camera Example Demos:
    http://107.170.59.150/
    This is now included in the bundle. Any camera owner can easily get and use All My Foscam IP Camera Examples Bundled Together With One Hour Of One-On-One Support To Implement Them Click Here!
    If you don't already have a website or a web server to host things like this or to store your IP Cameras Snapshot images and/or videos via FTP. All the examples here are hosted by DigitalOcean which I have found to have great prices and support. No domain name is required and you get your own unique IP Address and it's your Web Server, NOT shared!
    Click for more details
    Added Totally Secure Foscam IP Camera Display and Control Support. Even when using HTTP not just HTTPS.
    Prior to this release. Only Totally Secure Display was supported using HTTP or HTTPS not IP Camera Controls.
    All Foscam IP Camera Models can be configured for the size display of your choice. For demonstration purposes. A width of 640 pixels is being used while keeping the aspect ratio for height. But you can configure any default size and use the Interfaces infinite zoom as needed.
    Here is an example of a FI9826W using the actual default Snapshot resolution of 1280x720 instead of 640. The FI9826W is capable of default 1280x960 resolution but this one is at 1280x720:
    http://107.170.59.150/foscam/SecureI...layControl.htm
    You can also access the camera using HTTPS even if the camera is not using HTTPS for remote access. Access can be combined with your own unique login using the User Id and Password of your choice not connected with any User Id and/or Password for the camera itself. The optional logon can be used using HTTP or HTTPS. Try it here.
    Note: The HTTPS example is using a self-signed SSL certificate so you will see a warning when using the HTTPS link.
    User Id: admin
    Password: admin
    HTTP:
    http://107.170.59.150/foscam/SecureI...ntrolLogin.php
    HTTPS:
    https://107.170.59.150/foscam/Secure...ntrolLogin.php
    You can directly access the camera without the Logon using HTTPS as well:
    https://107.170.59.150/foscam/Secure...layControl.htm
    Foscam H.264 based IP Cameras Models FI9826W and FI9828W now support using both the cameras actual zoom lens as well as the Interfaces Infinite zoom ability. They can also be used together.
    All these options are configurable and can be enabled/disabled individually.
    Simply click on any of the Foscam IP Camera Models below to try a live demonstration for any of the IP Camera models:
    There is a Two Minute Limit For Demonstration Purposes
    Don
    New Live Demonstrations have been added for Hikvision and Panasonic IP Cameras here:
    http://107.170.59.150/Hikvision/
    As with the other demonstrations they can also use HTTPS access methods. The server hosting the demos is using a self-signed certificate so you will see warnings when using the link below:
    https://107.170.59.150/Hikvision/
    A unique logon and password can be required to access one or more IP Cameras if you wish as well.
    These methods can be used with communicating to the IP Cameras directly or via their iVMS/NVR/DVR as well.
    Please see the first post here for more details: http://board.homeseer.com/showpost.p...60&postcount=1
    Don
