Hi Blade,
any chance of looking into this?
My setup allows control of itunes via android (retune) and HS3, but not at the same time.
What I'm seeing is this:
1. Playlist is played using retune
2. Itunes is stopped/paused using retune
3. (some time later/next day) HS3 event fires to start up a specific playlist, which is different from played previously
4. Itunes plays the playlist which was played in #2
If I check the HS3 status when seeing this, it's always set to "library".
If I fire the event a few more times after forcing a stop, eventually it will actually set the playlist to the correct one.
