Set Device Nest Target Temperature not available
    Trying to set a schedule within HS but do not have any options to "set target temperature" as shown in your "documentation". The only Nest actions I have is "Nest Action" and under that only "set estimated time of arrival" - what ever that means. I can see no use of this function as the Nest knows when we arrive/leave home. I can change the temperature remotely on my phone so the estimated time of arrival is not worth much.
    Picking Control a Device I find "HVAC Mode" and "Target Temperature High/Low" but have no idea of what this means.
    There seems to be a lot missing from this plugin...
    I know scheduling can be done on the stat its self but would rather use HS for this purpose.
    you need to use a "Control Device" action, with the "Target temperature High/Low" device.
    Target temperature high is the cool setpoint
    Target temperature low is the heat setpoint
    what else are you missing?
      Okay, that helps...
      Fan control, my Honeywell had the option of fan on/off/circulation.
        the Nest plug-in creates a Fan device with On/Off controls that let you turn the fan on/off.
