OK, so I have a humidifier set up with an X10 appliance module (P1) that I control using a Palm Pad. The past few days it does not respond to any (on/off) command sent via the Palm Pad. I verified the log and the (P1) on/off is being logged in HS but the appliance module is not responding. Now if I go to the status page and click the ON/OFF via HS, it works. I wonder why it does not respond to the Palm Pad control even though the status is being logged as P1 OFF or ON?
Strange X10 issue
Originally posted by nsisman View PostSounds like the P1 is being sent OK by the palmpad but not being received by anything ?
Is P a new housecode for your system ?
Have you enabled housecode P in the ACRF plug in if you use that plug in or do you have a tm751 or equivalent set to code P to receive the rf ?
Neil
P1 is set up as the humidifier. It has been working flawlessly in the past. Again, the strange thing is that is showing in the log as changing:
10/17/2007 8:56:09 PM Info Device: Humidifier(P1) OFF <---from the log via PalmPad
I'm using the RFXCOM ACRF...
Originally posted by Rupp View PostDo you have the retransmit still set in the ACRF plugin?HW - i5 4570T @2.9ghz runs @11w | 8gb ram | 128gb ssd OS - Win10 x64
Originally posted by bmora View Postahhhh...
That's it guys!! I had the retransmit deselected! Thanks!HW - i5 4570T @2.9ghz runs @11w | 8gb ram | 128gb ssd OS - Win10 x64
