OK, did some more testing and I got it to work!
I changed the regional settings to use period as the decimal sign. Also to use period as the decimal sign for currency.
Then I tried the plugin, but no change.
I then startet playing around with the "mulitply by 100" again, and that did the trick this time!
Now my S1 temperature reports its device value as -400, so that worked fine.
However, the pressure devices still have some issues:
S1 pressure: Device String: 992.89 Device Value: 99289
S1 pressure High: Device String: 994.92 Device Value: 0
S1 pressure Low: Device String: 991.88 Device Value: 0
So now the S1 pressure works fine, but the highs and lows have Device Value = 0, even though all the devices have the same device string decimals...
Will report back any more changes.
