I recently had to reload due to a disk failure and in the process moved from 2.3 to 2.5. When I originally plugged in my USB stick (WDUSB-10) the XP system loaded the HID compliant drive and HS saw it and all was well. I scanned for new devices (I only have one) and it found it but then duplicated the original ones.
Like a fool I then deleted all the zwave devices hoping to just reset. Unfortunately a scan then wouldn't pick up the device any longer. To make matters worse I decided to then click the restart the zwave interface and it warned me this would delete the interface and I did it. Well now I'm getting this error at start up:
11/17/2011 11:01:53 PM Z-Wave -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 11/17/2011 11:01:53 PM Z-WaveError (Init/Sync) Initializing Z-Wave Interface: Cannot find USB Interface (3) 11/17/2011 11:01:53 PM Z-Wave Initializing Z-Wave Interface on USB 11/17/2011 11:01:53 PM Z-Wave :- :- :- :- :- :- :- :- Initializing Z-Wave Interface -: -: -: -: -: -: -: -:
I can see the USB Stick/HID driver is there via the device manager. I thought this might be a function that the stick was now plugged into a different USB slot it claims it's looking for Interface 3 but moving it around doesn't help. This is an XP machine running SP3 if it matters.
I noted that I can't see the zwave interface on the interface tab or the manage button so I went back to basics and went through the updater and it didn't recognize that the HomeSeer Zwave USB Drivers were installed. Ok, so I run through the update and restarted HS and there is still no Zwave USB driver interface.
I think if I can actually get these to install again it'll all work. But everytime I run the updater is doesn't think the driver is installed and claims to install it but it doesn't. I'm getting frantic to maybe try copying my old zwave drivers/setup from my 2.3 install but I need so guidance on the right way to fix this instead of me hacking at it.
What do I need to get my zwave interface back properly installed?
[IMG]file:///C:/Users/dickc/AppData/Local/Temp/moz-screenshot-6.png[/IMG][IMG]file:///C:/Users/dickc/AppData/Local/Temp/moz-screenshot-7.png[/IMG]
