Network Cameras that Work with UltraNetCam
    Trendnet TVIP672W and TVIP672P
    TVIP672W and P: /image/jpeg.cgi
      Could the Hikvision 3MP HD 1080P camera work with UltraNetCam?
      http://www.ebay.com/itm/HD-Pan-Tilt-...item5412203c94
        Grandstream IP HD
        /snapshot/view4.jpg
        /snapshot/view0.jpg
        Multi resolution choices on JPG's. I utilize JPGs and motion for HS3 touch.
        One is 1280X720 and the other is 640X368.
        I am running multiple resolution streaming / captures today of the Grandstream IP HD cameras.
          Just setup my Hikvision DS-2CD2232-I5
          Snapshot path is
          /Streaming/channels/1/picture
          I think this is common across all newer firmware Hikvisions.
            Amcrest IP2M Series
            /cgi-bin/snapshot.cgi?loginuse=$user&loginpas=$pass
            Seems to be working, still testing ...
            Based off info from here: https://www.ispyconnect.com/man.aspx?n=Amcrest
              #21
              Y-cam Cube : /live/0/jpeg.jpg
              Y-cam SD: /snapshot.jpg
              Trendnet TV-VS1 IP Encoder: /cgi/jpg/image.cgi
                #22
                Hi, I'm trying to get UltraNetCam to work with this camera. Based on the spec's, should it work? Been procrastinating on getting it to work and only have 3 days left on my UltraNetCam 30-day trial.
                http://www.ebay.com/itm/1080p-2-0-me...3D112126744592
                  #23
                  Do you happen to have the URL that displays the camera snapshot? That's typically all that is required to get a camera to work with my plug-in. If you need more trial time, please open a ticket with HomeSeer and ask them to extend your trial another 30 days.
                  Ultrajones
                    #24
                    Thanks for the response, I found this for the snapshot path:
                    snap.jpg?JpegSize=M
                    at a third party website http://www.ispyconnect.com/man.aspx?n=elp
                    but still haven't been able to get the snapshot.
                      #25
                      Any cameras that have TCP trigger
                      Anyone able to recommend reasonably priced TCP trigger enabled PTZ cameras that work with UltraNetCam? Indoor and Outdoor.
                      Would love to replace my Foscams that do not support TCP trigger.
                      I currently use email notifications from the Foscam cameras to trigger events. But that is less than satisfactory since there is a minimum 1 minute lag. HS3 can only check POP email every 1 minute. So combine that with the processing and email transmission lag, in reality it is more than a minute.
                      Th list on the OP does not tell me which have TCP trigger.
                        #26
                        Hello,
                        Wondering if you were ever able to get an Amcrest IP cam to work with this plugin? I'm considering purchasing but want to make sure they will be supported?
                        Thank you,
                        HS4 4.2.6.0 &HSTouch Designer 3.0.80
                        Plugin's:
                        BLBackup, BLOccupied, BLShutdown, EasyTrigger, Ecobee, Nest, AK Bond
                        weatherXML, Jon00 Alexa Helper, Network Monitor, MyQ, Z-Wave
                          #27
                          Any camera that provides a URL that outputs a snapshot directly will work with the plug-in. I no longer use Foscam or Amcrest cameras so I cannot confirm.
                            #28
                            Problem accessing the videopath
                            I am trying to configure new cams to my plugin but when creating or trying to edit the "NetCam Videostream Path:" filed, it is lock and I can't change the path.
                            Is this field still accessible ?
                              #29
                              Will this plugin work with cameras that require digest authentication? Or basic authentication not using URL basic authentication?
                                #30
                                will this plugin work with cameras on a different local network? ie. homeseer on 192. octet and cameras on 10. octet
                                thanks
