You can discuss the plugin features here
BLRadioRA discussion
Guest
1.0.5 works better
Phantom buttons are now updating properly, even to the point if one of my old dimmers ignores a command (due to not supporting fade time) the feedback is correct.
Chris
Guest
Phantom Button Toggle
For the Phantom buttons it may be better to use the toggle command {TOG], and just provide one button [as opposed to on and off]. The all on and all functionality makes more sense with one button also, but won't use the toggle command. If you look at one of the physical master controller's they only have one button to control a room/Scene.
Thanks for all your efforts.
The plugin is now in the store.
http://store.homeseer.com/store/Blad...P1667C268.aspx
The image is wrong but I still do not have the image done for it.
64 zones anyone
Hi Blade,
I used to write software long time ago in the Era of PL/I , Fortran etc. I'm no expert in today's technologies by any means. However I did review Lutron's protocol for control of Radio RA 1 over serial interface. There is an optional suffix in most commands ",1" or ",2" pertaining to subsystem 1 and subsystem 2. The default is 1. If you use this suffix you can extend the range of devices from current 32 devices to full 64 devices which is the max limit for Lutron Radio RA 1.
Can you do this for me please in the next release. Looks like relatively simple thing. If you do please let me know.
RI2
