An Outstanding PlugIn that I would highly recommend
    I had the good fortune of coming across this PlugIn for the Hayward Goldline Pool Controller that I have. The plugIn works great.
    The author was is very responsive to any questions and I really appreciated that.
    The documentation is clear and made it a snap to install and get running.
    The only issue I had was that I did not read the Hayward Serial Controller manual as it wanted the Serial port set to 19,200 baud instead of the default 9,600 baud that my system was setting the port to.
    The RS-232 setup should be asynchronous serial mode with 19.2K N82 (19200 baud, no parity, 8 data bits, 2 stop bits).
    Thank You
    Mike Lehrer
    Phoenix, Arizona
