If you are seeing delays in Z-Wave operations with plugin 3.0.1.124, please try the Beta 3.0.1.126 or later and see if this helps with the delays.
Delays with version 3.0.1.124
Tags: None
Yes, 126 has the changes, so load that one.
Originally posted by bebaldin View PostJust went to update it and it shows Beta 3.0.1.126 in the updater. Does this also have the timing updates of 125?
Rich, I just purchased the Z-Seer + tool and updated to 124 (prior to seeing there is 126 now). I haven't noticed any delays yet, but its also only been about an hour. Anyways, I did notice a couple things that I wanted to question. First when the tool is scanning, I noticed that when the node can talk directly to my Znet, the scan is quick. If it has to route thru another node, the scan pauses for a bit. My brain is thinking maybe there is something there in relation to the delays?? Or am I way off?
Also I have a question about the tool and the "test time". What does it mean? I am thinking seconds, but the whole test for my entire network (Roughly 75 nodes) didn't take that long as its stating just for this one node and you can see it has a lot of neighbors with the znet being the primary.
I will update to 126 and report back, and again appreciate the efforts into looking into the delays issue.
Thanks for the suggestions. .126 didn't show as available even though the list just refreshed. I had to purposely click on update listing, then it appeared.
Since .124 I have one ongoing error. weatherXML error - sort Tide List: Item has already been added. Key in dictionary: 1Startup Complete. 1 errors detected, check the log for more information.
Routing will slow things down, but if the route is solid, it should only be slightly slower than direct. If the RF is weak, it will be slower. Note that if you are testing a battery device that supports beaming, it could take a couple of seconds to just wake the device before the test packet can be sent. Also, the response test could be a lot slower as the end node may send the response through a bad route. If the test time is slow, try a few optimizations.
The test times are in seconds.milliseconds.
Originally posted by waynehead99 View PostRich, I just purchased the Z-Seer + tool and updated to 124 (prior to seeing there is 126 now). I haven't noticed any delays yet, but its also only been about an hour. Anyways, I did notice a couple things that I wanted to question. First when the tool is scanning, I noticed that when the node can talk directly to my Znet, the scan is quick. If it has to route thru another node, the scan pauses for a bit. My brain is thinking maybe there is something there in relation to the delays?? Or am I way off?
Things slowed to a crawl again a few minutes ago. I have been running a simple test every 3 minutes since this afternoon. This test turns a Z-Wave outlet on with one event and stats a timer. When the device reports that it is on a second event stops the timer and writes its value to the log. At 7:57PM my wife used the MiniMote to turn on the living room reading lights. She told me they took forever to turn on. At the same time my test event was delayed as well. Here are the log entries
Code:Jun-07 8:06:19 PM Delay Z-Wave delay test completion time 00:00:00.5104184 Jun-07 8:03:19 PM Delay Z-Wave delay test completion time 00:00:00.4323341 Jun-07 8:00:19 PM Delay Z-Wave delay test completion time 00:00:00.5729134 Jun-07 7:57:28 PM Delay Z-Wave delay test completion time 00:00:09.8385343 Jun-07 7:54:19 PM Delay Z-Wave delay test completion time 00:00:00.5260341 Jun-07 7:51:19 PM Delay Z-Wave delay test completion time 00:00:00.4479048 Jun-07 7:48:19 PM Delay Z-Wave delay test completion time 00:00:00.6041677 Jun-07 7:45:19 PM Delay Z-Wave delay test completion time 00:00:00.5572927 Jun-07 7:42:19 PM Delay Z-Wave delay test completion time 00:00:00.4635245
Code:Jun-07 8:12:19 PM Delay Z-Wave delay test completion time 00:00:00.4635605 Jun-07 8:09:19 PM Delay Z-Wave delay test completion time 00:00:00.5416736 Jun-07 8:06:19 PM Delay Z-Wave delay test completion time 00:00:00.5104184 Jun-07 8:03:19 PM Delay Z-Wave delay test completion time 00:00:00.4323341 Jun-07 8:00:19 PM Delay Z-Wave delay test completion time 00:00:00.5729134 Jun-07 7:57:28 PM Delay Z-Wave delay test completion time 00:00:09.8385343 Jun-07 7:54:19 PM Delay Z-Wave delay test completion time 00:00:00.5260341 Jun-07 7:51:19 PM Delay Z-Wave delay test completion time 00:00:00.4479048 Jun-07 7:48:19 PM Delay Z-Wave delay test completion time 00:00:00.6041677 Jun-07 7:45:19 PM Delay Z-Wave delay test completion time 00:00:00.5572927 Jun-07 7:42:19 PM Delay Z-Wave delay test completion time 00:00:00.4635245 Jun-07 7:11:23 PM Delay Z-Wave delay test completion time 00:00:00.3598037 Jun-07 7:08:45 PM Delay Z-Wave delay test completion time 00:00:22.4691515 Jun-07 7:05:41 PM Delay Z-Wave delay test completion time 00:00:18.6522991 Jun-07 7:02:23 PM Delay Z-Wave delay test completion time 00:00:00.4228145 Jun-07 6:59:23 PM Delay Z-Wave delay test completion time 00:00:00.4708187 Jun-07 6:56:23 PM Delay Z-Wave delay test completion time 00:00:00.2976707 Jun-07 6:53:23 PM Delay Z-Wave delay test completion time 00:00:00.4226351 Jun-07 6:50:23 PM Delay Z-Wave delay test completion time 00:00:00.4069772 Jun-07 6:47:23 PM Delay Z-Wave delay test completion time 00:00:00.1764376 Jun-07 6:44:23 PM Delay Z-Wave delay test completion time 00:00:00.5783442 Jun-07 6:41:23 PM Delay Z-Wave delay test completion time 00:00:00.3915011 Jun-07 6:38:23 PM Delay Z-Wave delay test completion time 00:00:00.3657649 Jun-07 6:35:23 PM Delay Z-Wave delay test completion time 00:00:00.5319420 Jun-07 6:32:23 PM Delay Z-Wave delay test completion time 00:00:00.5632014 Jun-07 6:29:23 PM Delay Z-Wave delay test completion time 00:00:00.4693519 Jun-07 6:26:25 PM Delay Z-Wave delay test completion time 00:00:02.1724465 Jun-07 6:23:23 PM Delay Z-Wave delay test completion time 00:00:00.2660852 Jun-07 6:20:23 PM Delay Z-Wave delay test completion time 00:00:00.4382462 Jun-07 6:17:23 PM Delay Z-Wave delay test completion time 00:00:00.3129584 Jun-07 6:14:23 PM Delay Z-Wave delay test completion time 00:00:00.2073258 Jun-07 6:11:23 PM Delay Z-Wave delay test completion time 00:00:00.4383098 Jun-07 6:08:23 PM Delay Z-Wave delay test completion time 00:00:00.5006783 Jun-07 6:05:24 PM Delay Z-Wave delay test completion time 00:00:01.0006454 Jun-07 6:02:23 PM Delay Z-Wave delay test completion time 00:00:00.5477203 Jun-07 5:59:23 PM Delay Z-Wave delay test completion time 00:00:00.6100510 Jun-07 5:56:23 PM Delay Z-Wave delay test completion time 00:00:00.4068941 Jun-07 5:53:23 PM Delay Z-Wave delay test completion time 00:00:00.6568612 Jun-07 5:50:23 PM Delay Z-Wave delay test completion time 00:00:00.2817381 Jun-07 5:47:24 PM Delay Z-Wave delay test completion time 00:00:01.1567675 Jun-07 5:44:23 PM Delay Z-Wave delay test completion time 00:00:00.3910469 Jun-07 5:41:23 PM Delay Z-Wave delay test completion time 00:00:00.4883065 Jun-07 5:38:23 PM Delay Z-Wave delay test completion time 00:00:00.5318343 Jun-07 5:35:23 PM Delay Z-Wave delay test completion time 00:00:00.5005322 Jun-07 5:32:23 PM Delay Z-Wave delay test completion time 00:00:00.3304244 Jun-07 5:29:23 PM Delay Z-Wave delay test completion time 00:00:00.5790867 Jun-07 5:26:23 PM Delay Z-Wave delay test completion time 00:00:00.4213536 Jun-07 5:23:23 PM Delay Z-Wave delay test completion time 00:00:00.2971373 Jun-07 5:20:23 PM Delay Z-Wave delay test completion time 00:00:00.1580102 Jun-07 5:17:30 PM Delay Z-Wave delay test completion time 00:00:07.3758463 Jun-07 5:14:23 PM Delay Z-Wave delay test completion time 00:00:00.5630738 Jun-07 5:11:23 PM Delay Z-Wave delay test completion time 00:00:00.4692281 Jun-07 5:08:33 PM Delay Z-Wave delay test completion time 00:00:10.4852379 Jun-07 5:05:23 PM Delay Z-Wave delay test completion time 00:00:00.4383644 Jun-07 5:02:23 PM Delay Z-Wave delay test completion time 00:00:00.3601676 Jun-07 4:59:23 PM Delay Z-Wave delay test completion time 00:00:00.3913842 Jun-07 4:56:23 PM Delay Z-Wave delay test completion time 00:00:00.3913578 Jun-07 4:53:23 PM Delay Z-Wave delay test completion time 00:00:00.6725697 Jun-07 4:50:33 PM Delay Z-Wave delay test completion time 00:00:10.5477188 Jun-07 4:47:47 PM Delay Z-Wave delay test completion time 00:00:24.6883073 Jun-07 4:44:49 PM Delay Z-Wave delay test completion time 00:00:26.8757775 Jun-07 4:41:23 PM Delay Z-Wave delay test completion time 00:00:00.5236752 Jun-07 4:38:27 PM Delay Z-Wave delay test completion time 00:00:04.0473495 Jun-07 4:35:23 PM Delay Z-Wave delay test completion time 00:00:00.3760238 Jun-07 4:32:23 PM Delay Z-Wave delay test completion time 00:00:00.3600752 Jun-07 4:29:23 PM Delay Z-Wave delay test completion time 00:00:00.2819166 Jun-07 4:26:23 PM Delay Z-Wave delay test completion time 00:00:00.3453317 Jun-07 4:23:23 PM Delay Z-Wave delay test completion time 00:00:00.4378319 Jun-07 4:20:23 PM Delay Z-Wave delay test completion time 00:00:00.9172442 Jun-07 4:17:50 PM Delay Z-Wave delay test completion time 00:00:27.3601695 Jun-07 4:14:23 PM Delay Z-Wave delay test completion time 00:00:00.6257427 Jun-07 4:11:23 PM Delay Z-Wave delay test completion time 00:00:00.3132113 Jun-07 4:08:27 PM Delay Z-Wave delay test completion time 00:00:00.3066288 Jun-07 4:05:23 PM Delay Z-Wave delay test completion time 00:00:00.1468182 Jun-07 4:02:23 PM Delay Z-Wave delay test completion time 00:00:00.3127648 Jun-07 3:59:23 PM Delay Z-Wave delay test completion time 00:00:00.6883120
I was at .98 and it just worked. Updated to .124 and had some delays and then .126 and walked into the bathroom and it took 22 seconds to turn the light on. No Bueno.
Should've stayed at .98 but wanted to try the z-seer and the functionality to set lock codes.
Nearly all of my nodes are direct and the vast majority of my hardware is from HST - switches, dimmers and HSM200s.
WAF is going down hill...
Please keep us informed, Randy.Michael
Originally posted by Rvtravlr View PostI was at .98 and it just worked. Updated to .124 and had some delays and then .126 and walked into the bathroom and it took 22 seconds to turn the light on. No Bueno.
You can pull the .98 zwave exe from a backup and dump that into your HS folder to downgrade back to get the WAF back
