I have several Speaker Apps running on PC's connected to LAN(not on HS Server).
When I use the IP address(i.e. 192.168.1.113) they connect and work fine.
But when I use the PC name of the HS Server(i.e. ENTCENTER) it will not connect. The Name works in all other "http://ENTCENTER/*** " browser address accesses.
I have historically use IP addresses but would like to start using Name since it changes less often.
Is there some format issue? Or could some one confirm that they use Name in the Speaker App.
BobSpen
BobSpen
