MCO TPS314 Switch
    MCO TPS314 Switch
    Can anyone shed light on this, please?
    I got a couple of these switches and bench tested one that worked just fine, sent and received commands instantly but when I installed them I can ping and control them from HS but, I can't get HS to see their status or they're not sending it, can't work it out.
    Checking the log I get this, that I presume is an error of some sort:
    Instant status and sensor wake-up notifications are not being programmed because HomeSeer is being used as an installation tool only.
    At a guess, it's a setup thing, probably something basic I'm missing.
    The manual for the switch is here:
    http://www.mcohome.com/upload/file/20180227/20180227144616.pdf
    I played about a bit with it and on one of the switches I got it to turn on and off a light and, it *eventually* switched it on but I couldn't get it to switch back off. Send the on/off from HS direct to the switch and it works instantly.
    Any ideas?
    K.
    I figured it out an, in case it helps others, what you need to do is associate the various functions to Homeseer on the switch and fathom the hex codes to do that.
    K.
