Upgrading HomeSeer 2 to HomeSeer Pro - First cut
    #31
    Did you see my post?
      #32
      yep, but sorry I am not really sure of what is next.
      danielbo
        #33
        Upgrade
        I have a question, I have had HS2 for quite a while now. I have purchased the upgrade today and next week I want to install HS2 Pro as a fresh install and only copy over my HS database and ini file. What is the correct way to go about this? I donot want to download over my old version. I was going to start with a clean fresh install of windows and then HS2Pro.
        Thanks Dave....
          #34
          Have you considered restoring your HS2 backup and just using the HS2-to-HSPro upgrade Rupp added to the first post in this thread. It was 100% painless for me to use the upgrade versus the manual method of having to copy files back from my backup.
          John
          Hardware: i5-6400T w/16GB RAM & SSD w/HS3Pro, Z-Net, Harmony Hub x2, Echo Dot x2, Ocelot
          Plugins: Z-wave, HSTouch, BLBackup, Harmony, GTS CPUXA, UltraMon3, Nest
          HSTouch: Multiple Android Devices; 5 x ToteVision MD-1001 10.1" Win 7 Tablets
          Devices: Cooper RF9501 x4, RF9517 x6, RF9534 x1, RF9540-N x7, RF9542 x1, RF9542-Z x2, RFHDSCG x1, RFWC5 x5; Intermatic HA02 x6; FortrezZ MIMOLite x3; Leviton VRPD3-1LW x4, VRR15-1LZ x6; Nest Tstat & 9x Protects; Dragon PD-100 x3, PA-100 x3
            #35
            I had considered that , however I have been having some strange problems with IE and hs i always get a java script error on certain lines for the events page and have not been able to repair it. I posted to the board with no helpl So i thought it might be time to start from scratch again.
              #36
              Try upgrading to the latest version of Java - it's available as a MS upgrade.
              You could also try a NET repair.
              sigpic
                #37
                Gogs, thanks for the suggestion but i have tried both, that is why i was going to do a clean install.
                  #38
                  What version of IE are we talking about, and are we talking about the HS computer?
                  sigpic
                    #39
                    It doesn't work for me ...
                    In fact i had the 2.3.0.122 HS2 version ...
                    And when i install the HSPRO version update v.86 after the v.19, i have this error message :
                    this is normal ?
                      #40
                      Originally posted by nslmanu View Post
                      this is normal ?
                      If you upgrade to HomeSeer Pro you MUST upgrade to the same version number of your old HomeSeer 2 installation, if you installed HomeSeer Pro into the same directory.
                      So you were running a beta HomeSeer 2 you have to upgrade to at least the same beta version number of HomeSeer Pro.
                      Said another way. If you were running HomeSeer 2 version 2.3.122 you must upgrade to HomeSeer Pro and then apply the HomeSeer Pro 2.3.122 beta upgrade version.
                        #41
                        this is normal ?
                        Did you uninstal HS before upgrading, also did you let HSPro run in it's downloable version as from HST's website, not the updater.
                        sigpic
                          #42
                          Ok , it's done ... but now i have all my devices UNKNOWN ...
                            #43
                            Did you install HomeSeer Pro into the same directory as your older HomeSeer 2 was installed to as directed in the sticky?
                              #44
                              Erm Rupp, I don't think you are quite right in that statement.
                              I was running .66, uninsulated it and installed Professional Edition 2.3.0.19. as was downloaded from the HST main web site. It's running a treat, have not gone near the updater apart from HSTouch. I only have one problem and that is with one of Jonn00's scripts (The Horoscope one), it don't work, not a big problem.
                              I think the advice should be install the basic released download, get it working, then go from there.
                              sigpic
                                #45
                                Yes exaclty the same directory .... for my scripts ...
                                really strange ...
                                i take my backup files : settings.ini and condig database file ...
