Is it possible to measure signal strength detected by rfxcom receiver in HS2? I enabled RSSI in plug in but that field is not populated.
how to measure signal strength
yes, 5 is about the limit.
Maybe another antenna will improve the signal strength.
http://www.ebay.com/itm/GSM-GPRS-Ant...-/400985451637
http://www.ebay.com/itm/1pc-3dbi-433...-/232299077178
For the best results install this antenna on a 30 cm metal base plate.
Dos it make a difference if I have the magnetic base or a sucker base ? I am currently using a 30cm (1ft) whip antenna which has a sma connector, and that is screwed straight into the Rfxcom, so I think that is already better than the original which came with it. But I obviously need something even better.
