Originally posted by pcp
View Post
It is a playlist Joy and plays well when I use the Squeezebox server. The script ends with no error. But when I run this, music stops on the squeezeboxes. I will try with artists or genres tonight.
For the wavein I have installed the wavein plugin in the squeezebox server. Enabled speech in your plugins configuration and named the speakerclient "Squeezer". I addressed speech to (HSServer):Squeezer. Should I configure anything else?
If I use it this way the phisical squeezebox shows a http address on the display and ends with showing "wavein" on the display. And this stays until I press play on the squeezebox server or remote.
If I use the TTS on the machine it works fine, rate and pitch are working as expected. When I choose not to use wavein in your plugin and address the Squeezer client, speech words are played on the squeezebox but way to fast. Changing the rate does not help. Where the normal speaker client is working perfect on the same HS server.
Wim
