Hi
I have some problems with HS3 and fibaro devices FGD211 & FGS221
How can I associate relay switсh with motion sensors that they will work together in one Z-Wave network, but without Z-Stick and HomeSeer Pro?
I'd like to get configured the S2 key controls of the FGD211 with some other lights in the same room.
The other light is connected to a Fibaro FGS221 2*1.5kw relay switch, which has also been configured and is working fine when controlled locally from a switch and remotely via the z-wave controller.Within Homeseer, the relay switch appears as 3 devices: a base/root device and two binary switches.
When I open up the Homeseer association screen for the dimmer FGD211, I want to select Group 2 (which is the one of the S2 switch triggers) but the destination pulldown only lists the relay base/root device and not the binary switch I want to operate. The problem used to exist with HSPRO2 but doesn't seem to be fixed.
How should i do to use my fibaro devices ?
Many thanks
Please, I need your help!
Many thanks
