Hi, is it possible to run the MeiKu plugin from a machine other than the HS3?
Basically the connection for the plugin needs to connect to an IP address other than 127.0.0.1. Perhaps a command line option could allow this (how I have done it with my plugins).
The reason I ask is my Roku box is on another segment and it has been configured to talk to a VPN router for Internet access meaning it can't see other subnets in my local network. It can therefore only communicate locally on it's local subnet and the HS3 server is not there.
What I need to do is install this plugin on the same subnet as the Roku and then have the plugin connect over the internal network to the HS3 server (via a layer 3 switch).
4 boxes in the IP flow:
HS3 > L3 switch > MeiKu plugin > Roku
For this to work, I need a version of the plugin where I can specify the IP address of HS3 as I run it, for example:
HSPI_MeiKu.exe 10.10.10.10
Many thanks,
Chris
Many thanks,
Chris
