Originally posted by tCC
View Post
LAMetric Time Plugin
I've just uploaded version .7 to the updater, it should now allow you to control some applications on the LAMetric device as well as to switch between applications.
This means certain applications like the alarm clock, stop watch, countdown clock etc can be configured from HomeSeer to a specific time - handy if you want a kitchen timer set from HS.
As I can't test every app available it could be that some options don't work right, if this is the case tell me the app name and I'll try and fix it.
Originally posted by mrhappy View PostI've just uploaded version .7 to the updater, it should now allow you to control some applications on the LAMetric device as well as to switch between applications.
ThanksLast edited by anthonyb; April 8, 2017, 05:22 AM.
Originally posted by anthonyb View PostAre you able to test the alarm options? I can switch apps (which is brilliant) but I cant Enable or Disable my Alarm using the the clock app options at the moment.
What I know though is according to the reply I get from the unit the send command was successful and I'd like to think that if there was an issue it would reply that there was a fault. If you look at the attached you can see the data that I send and the data that comes back, if you compare it to this http://lametric-documentation.readth...vice-apps.html then from what I see it should work.
I'll make some enquiries and let you know...Last edited by mrhappy; November 6, 2017, 12:26 PM.
Regardless version .8 should fix it and that version is now in the updater for you.
Originally posted by spike5884 View PostIs there something special you have to do to have your device show up to get the API Key?
I have the unit set-up and iPhone communicating to it.
When I go to the developer website and then devices page, it does not show up.
Just as a test try and create a notification app, you can just put false values in the fields it is not important and then with an app created go back into the devices screen just in case this encourages it to get a list of your devices.
After re-tracing my steps a few time, I finally noticed that I had miss-entered my email address in the iPhone app during the initial device set-up. Missing the o in .com
Starting to play now.
Thanks.
Great plugin, everything work great. The only trouble I'm having is setting up the icon. I followed the instructions and edited the Config INI file with the [Icons]IconList=m4584,s37,m2867 line and the icon ID that I wanted but, they do not show up after i restart the plugin or HS.
any suggestions?
Originally posted by eallen40 View PostGreat plugin, everything work great. The only trouble I'm having is setting up the icon. I followed the instructions and edited the Config INI file with the [Icons]IconList=m4584,s37,m2867 line and the icon ID that I wanted but, they do not show up after i restart the plugin or HS.
any suggestions?
any suggestions?
