Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Help > How-To's
How-To's This area provides in-depth information on how to do something in HomeSeer or home automation.
  #21
Old June 10th, 2018, 11:02 AM
Pete's Avatar
Pete Pete is offline
OverSeer
@Matthew,
PFSense is very tight on purpose and really not made to remote control from another device.
You can circumvent the security on it to remote control it say with Homeseer.
I would not recommend this.
Personally I use Linux for my HomeSeer box here. Historically I have used scripts to SSH to my RPi to run stuff there or to move files et al. It was a kludge doing this and I used an exchange of the encryption keys between Homeseer and the RPi. That said google the command lines used for development on PFSense for a list of what you can do via command line. (just about anything).
The other way mentioned was to use php. The PFSense box is running on BSD and uses php. You would have to write a script that logs in to your PFSense box from Homeseer then have the script execute php commands directly on the PFSense box.
I have not attempted this. You can give it a try logging in to your PFSense box from the Homeseer box and doing a source look up of the page you are accessing to see the specific php command you are executing.
can homeseer control pfsense. for example if I wanted to issue a voice command to restart the appliance?
Yes but you will be circumventing PFSense punching a hole in to it for remote management which I would not recommend.
Automator
HS3 Pro & Lite Edition Beta 3.0.0.435
  #22
Old June 17th, 2018, 09:36 AM
Mwillis's Avatar
Mwillis Mwillis is offline
Seer Deluxe
Quote:
Originally Posted by Pete View Post
@Matthew,
you are misunderstanding.. I do not need to know the commands.. I do not know how to have homeseer open a SSH session to any device and run commands...
How do you do that?
HS3 Pro Edition
3.0.0.425
Microsoft Windows 10 Enterprise - Hyper-V VM
Number of Devices: 515
Number of Events: 109
Available Threads: 400
HSTouch Enabled: True
Enabled Plug-Ins
BLGarbage - BLLock - BLMapper - BLReminders - BLSecurity - BLSpeech - BLStat - BLTouchString - Blue-Iris - EasyTrigger - Insteon - Kinect - NetCAM - Random - Restart - UltraECM3 - UltraGCIR3 - UltraLog3 - UltraPioneerAVR3 - weatherXML - XBMC - Z-Wave
  #23
Old June 17th, 2018, 09:53 AM
Pete's Avatar
OverSeer
Using Windows you can write a script using Putty to SSH to the PFSense BSD box.
You need to know the commands in order to write a script to do this running Homeseer 3 in windows or linux. That is why Homeseer is so flexible.
The PuTTY command line
remote ssh tcl
  #24
Old June 17th, 2018, 10:44 AM
Mwillis's Avatar
Seer Deluxe
remote ssh tcl
interesting. Im still working on my system. I prob will not actually set it up. but good to know anyway. I have many devices that SSH can be used with.
  #25
Old June 17th, 2018, 10:48 AM
Pete's Avatar
OverSeer
I used to copy files between HS3 computers using SSH then went to sharing data directories and today playing a bit with using Mosquitto.
Personally I have never needed to reboot or reset PFSense. You do not want to power it off cold as you will corrupt the files running.
Google the command line for restarting PFSense.
I have historically had issues with the older combo firewalls that would need to reboot to get them going again because of the SOHO firmware that never was updated.
HTML code is On
PFSense Firewall Group purchase interest Pete Personal Computers 421 February 21st, 2018 07:42 AM
PFSense VPN Easy Peasy way Pete How-To's 0 June 13th, 2016 05:03 AM
Using UltraLog3 HSPI Syslog with pfSense Firewall 2.3 Ultrajones UltraLog HSPI 0 February 21st, 2015 06:36 PM
PFSense VPN Tunnel Use Pete How-To's 0 August 21st, 2014 07:09 AM
how to configure an iTach device behind a wifi firewall waninae39 HomeSeer Global Cache Plug-in 9 October 27th, 2012 12:59 PM
