Go Back   HomeSeer Message Board > User Interface Plug-ins > User Interface Discussion
User Interface Discussion User Interface Plug-ins
  #301
Old June 8th, 2018, 06:02 PM
Jobee Jobee is offline
Seer Deluxe
Quote:
Originally Posted by avargaskun View Post
Hi Michael,
Can you try turning off your phone's WiFi and navigating to your HS3 homepage on your phone's web browser? Does that work? I wonder if there is something blocking external connections to your server and, even with only the default connection enabled in HSBuddy, your phone is still hitting the server from within your local network when WiFi is on, rather than going out and back in through your router.
Also, after trying and failing a connection test, could you send me feedback from the app? (by default you can do this by shaking the phone while the app is open). That will include logs that may help troubleshoot.
Antonio
So I figured it out. My ISP messed up my subnet and static IP range so they were directing one of my IPs to somewhere else and that was the IP I selected to use. Once I picked a different IP, it worked like a charm.
Now to go after them to get my IP back...
HS3Pro on Win2012R2
Aeotec, Cooper, Cree, GE/Jasco, Intermatic, LIFX, Fortrezz, OSRAM, RCS, Trane, Zooz
BLBackup, BLGData, BLRussound, BLSpeech, HSTouch, InvisaLink, HSBuddy, IFTTT, NetCAM, PHLocation, Pushover 3P, Random, UltraLighting3, weatherXML, ZigBee, Z-Wave
  #302
Old June 8th, 2018, 09:43 PM
TeleFragger's Avatar
TeleFragger TeleFragger is offline
OverSeer
I can confirm I experience the same issue when I configure my app to use MyHS. For the longest time I've been using direct connection, so I wouldn't be surprised if this is something that changed since in MyHS.
I believe I have a fix for this - I will try to get a change out to the stores as soon as possible.
wow... I didn't realize that. I haven't been home much.. but yes works that way..
  #303
Old June 8th, 2018, 10:08 PM
avargaskun's Avatar
avargaskun avargaskun is offline
Seer Plus
Quote:
Btw, I've pushed an update for Android (1.0.28) that should address the issue for MyHS images. It seems to work in my own device. The version for iOS is pending approval from the store.
Seems like you're using it in Android, could you confirm if the issue is fixed in the newest version of the app?
Antonio
  #304
Old June 8th, 2018, 10:09 PM
avargaskun's Avatar
Seer Plus
Thanks for the confirmation!
  #305
Old June 8th, 2018, 10:15 PM
OverSeer
Antonio
Appears to b working on android now. Thx. Not connected to wifi... and works. Pics in morning. On phone and dont see attachment button. Gnight
  #306
Old June 9th, 2018, 01:41 PM
scyto scyto is offline
Seer
Plugin Never starts
I have the plugin installed, it never starts. Just says INFO: plugin start is pending
I have all my UI items as shown in this thread, with the exception of my local port is 8036 (this is running on a macvlan docker container, 80 is already in use by the docker host)
Any ideas?
PS why is there not a dedicated forum for this plugin?
  #307
Old June 9th, 2018, 11:07 PM
avargaskun's Avatar
Seer Plus
Any ideas?
Is there anything in the logs at the time you try to start the plugin?
  #308
Old June 10th, 2018, 02:53 PM
Seer
Hi, thanks for the question. There are no errors in the startup log or console output.
I do see this on system startup
Jun-10 11:54:05
Plug-In Finished initializing plug-in HSBuddy
But it still shows as pending in the UI.
I am running this plug in a homeseer docker container https://hub.docker.com/r/marthoc/homeseer/
I don't think there are Linux dependencies missing it is running a 5.x mono build and in installed mono-complete just incase.
the process doesn't seem to be running (see attached)
Is there somewhere else I can look for this plugin?
alex
  #309
Old June 10th, 2018, 08:54 PM
avargaskun's Avatar
Seer Plus
Hi Alex,
That link was very useful. I looked into it and turns out that this container does not run HS3 from the install folder (/homeseer) but rather from root (/) which caused the plugin to fail at launch.
I've put a new version of the plugin out which fixes this - I've tested it myself using the same docker container image. It still shows the "pending start" status right after starting the plugin, but if you refresh the page 3-5 seconds later it shows as OK and the HSBuddy menu now shows under PLUG-INS.
Antonio
  #310
Old June 10th, 2018, 09:43 PM
Tillsy's Avatar
Tillsy Tillsy is offline
Seer
I'm installed in /usr/local/HomeSeer and was running this plugin fine - but then a couple days ago it became stuck at the pending.
Whatever you did in this latest update has corrected that.
I am curious though - clearly your app talks direct to HomeSeer, as with the plugin offline the app still worked fine, so I am wondering what the plugin is actually doing... just a few odds and ends that can't be done via the JSON interface?
  #311
Old June 10th, 2018, 10:56 PM
avargaskun's Avatar
Seer Plus
Hello,
Thanks for letting me know! Not sure in your case why it may have stopped working recently - but it's good to know that has been resolved.
There's a few things related to devices and events that the plugin does which are not possible with JSON. Beyond that, there's features that are implemented entirely within the plugin. I think the list goes as follows:
  • Enabling/disabling events
  • Reading the new 'Hide from mobile views' setting of each device
  • Getting history of device status changes
  • Viewing cameras
  • Location-based event triggers
  • Push notifications
And there's still a few left in my to-do list
-Antonio
  #312
Old June 11th, 2018, 02:04 AM
Seer
Hi Alex,
Antonio
Thanks, yup, that fixed it!
not sure what you mean by in root, mine is absolutely in /HomeSeer/ via the mapped folder!? (Did you create a mapped folder?)
Edit, ah you mean the mono, yeah it is run from /usr/bin/mono for all hspi processes, but from root for the hsconsole though my hsconsole is in /HomeSeer - I did see some issues in log, I will post when I have time.
Is there one change I should be asking the container owner to make to his image?
  #313
Old June 14th, 2018, 08:32 AM
jagaliano jagaliano is offline
Seer
HSBuddy Crashing in HomeTroller Sel Pro
Dear Antonio:
I have a new HomeTroller Sel Pro. I updated it to .435, and installed BLBackup.
Mono is 5.0.1.1. I didn't run yet apt-get upgrade.
When I try to start HSBuddy It crashes with the following log message:
Initializing plug-in(1): HSBuddy Instance::System.TypeLoadException: Could not load type of field 'HSPI_HSBuddy.Data.Database:k__BackingField' (2) due to: Could not load file or assembly 'System.Runtime, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. assembly:System.Runtime, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a type: member: at HSPI_HSBuddy.HSPI.InitIO (System.String port) [0x00011] in <9d46cb9554394ff7a50f37bb6eb66665>:0 Time to load: 71 milliseconds
I don't know if updating Mono to the latest relase will resolve the issue. Could you please let me know.
I am still playing with the marthoc Docker container and there it works properly.
Thank you very much in advance.
Regards,
José
  #314
Old June 14th, 2018, 08:21 PM
avargaskun's Avatar
Seer Plus
I haven't done much testing with Mono 5, but have you installed the mono-devel package as well?
Antonio
  #315
Old June 15th, 2018, 08:21 AM
Seer
Antonio
Being a new Hometroller-SEL Pro I just assumed it was installed. I was wrong!.
Homeseer ships new SELs with Mono 5.0.1.1, but broken dependencies as you can see.
homeseer@hometrollerSEL:~$ sudo apt-get install -s mono-devel
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
mono-devel : Depends: libglib2.0-0 (>= 2.40.2) but 2.40.0-2 is to be installed
Recommends: referenceassemblies-pcl but it is not going to be installed
Recommends: msbuild but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Could please give advice of how to correct the situation.
Regards,
José.
  #316
Old June 15th, 2018, 01:59 PM
spud's Avatar
spud spud is offline
Moderator
Quote:
Originally Posted by jagaliano View Post
Regards,
José.
When did you buy your SEL?
Some SEL users had the same exact problem with the Ecobee and Chromecast plugins, but I thought HST had fixed this issue on the most recent version of the SEL.
  #317
Old June 15th, 2018, 02:26 PM
Seer
I bought it one week ago. And I cannot understand why the problem is still here (I already read an old comment from you).
HST Help Desk recommends me to run mono5.sh, which is not going to fix anything, because libglib2 won't be updated by apt-get dist-upgrade. I have checked it running:
"apt-get -o=APT::Get::Show-User-Simulation-Note=no --simulate dist-upgrade"
If you have any idea of what can I do, please let me know.
Regards,
José
P.S.: By the way, I am going to buy Easy Trigger. Nice plugin, great job!
  #318
Old June 16th, 2018, 02:45 PM
chaqita chaqita is offline
Seer
Cannot find the Plugin
I've rebooted, updated HS3 to 3.0.0.435, and the HSbuddy plugin is not showing available to install in the User Interface category. Any thoughts?
  #319
Old June 16th, 2018, 09:54 PM
avargaskun's Avatar
Seer Plus
Quote:
That's weird. I'm also using build 435 on Windows and it shows up. I've tested it using build 435 on Linux as well. What platform are you running HS3 on?
  #320
Old June 16th, 2018, 09:57 PM
Seer
Windows 10
Tags
app, client, mobile, phone, remote
HTML code is Off
All-In-One Mobile UI ... iPhone, Windows Mobile, etc alevey Web Server and Interface 11 February 7th, 2013 12:11 PM
Mobile brenton.prettejohn pjc Network 0 September 19th, 2011 04:27 AM
Mobile Backup darren-mc SMS Connector 0 August 23rd, 2010 04:46 AM
Windows Mobile Help 68sting Clients - Windows CE / Mobile 0 October 23rd, 2009 05:53 PM
Help with Windows Mobile Please phillb Clients - Windows CE / Mobile 4 February 25th, 2009 06:49 PM
