Go Back   HomeSeer Message Board > Wireless Receiver & Transceiver Plug-ins > Wireless Receiver & Transceiver Discussion > RFXCOM Plug-In (3P)
RFXCOM Plug-In (3P) Discussion area for the RFXCOM 3rd party plug-in.
Old June 10th, 2018, 05:14 PM
wadesready wadesready is offline
Seer Deluxe
rfxcom and DS10A
Do the Powerhouse x10 DS10A door sensors work with the rfxcom plugin? or do I just have a bad sensor?
The plugin does not see it at all.
Old June 10th, 2018, 05:42 PM
b_weijenberg b_weijenberg is offline
OverSeer
Yes the plugin supports this sensor .
Which receiver do you use?
Old June 11th, 2018, 03:37 AM
OverSeer
I suppose you have a W800.
Did you enable the X10 and 32bit selection on the RFXCOM - Receiver configuration page?
Enable debug level 2 for the receivers on the RFXCOM - General config page. Check the HS log if something is received.
Old June 11th, 2018, 06:10 AM
Seer Deluxe
I have the 433trx, I have x10 enabled in the trx manager but I don't see anything there either. I had trouble even getting the light to come on when I first put in the batteries, so maybe it is a bad device. after taking the batteries out and putting different batteries in several times it finally started lighting up.
Old June 11th, 2018, 06:52 AM
OverSeer
The RFXtrx433E operates at 433MHz while US X10 sensors like the DS10A operate at 310MHZ!!!
Best is to use the W800RF32A receiver for US X10 sensors and configure this in the RFXCOM plugin as 32bit receiver.
Old June 11th, 2018, 09:13 AM
Seer Deluxe
maybe I should read more ya think? hahaha thanks for the info!
HTML code is On
RFXCOM errors on a device code which isnt being used by RFXCOM Dup RFXCOM Plug-In (3P) 3 April 14th, 2011 08:42 PM
Reading RFXCOM.mdb Data Into RFXCharts Without RFXCOM Plug-In... Dave Haig RFXCOM Plug-In (3P) 6 February 1st, 2009 02:23 PM
ACRF/RFXCOM DS10A Log File graytech ACRF Processor (3P) 5 May 23rd, 2007 01:12 PM
DS10a & Elk-930 jrfuda W800 RF Receiver (3P) 5 August 3rd, 2005 08:43 AM
DS10A uses christopherhallowell HomeSeer General Discussion Area 8 July 28th, 2005 10:45 PM
