Go Back   HomeSeer Message Board > General Home Automation > General Home Automation Hardware Discussion
Old June 6th, 2018, 04:59 PM
Summerguy's Avatar
Summerguy Summerguy is online now
Seer Deluxe
Lattepanda boards
Hey,
What do you think about theses boards?
https://www.board-db.org/compare/221,223,222/
Do you think the delta would have enought of cpu power and ram for homeseer?
The arduino seems to be a nice addon
Old June 6th, 2018, 09:30 PM
Summerguy's Avatar
Seer Deluxe
The form factor is a little bigger than the pi and it can run windows 10
Old June 11th, 2018, 03:20 PM
ShawnB ShawnB is offline
Viewer
I think the Delta should be enough for a standalone HS3 install.
HomeSeer's HomeTroller S6 PRO has a Celeron 3205U processor (2 cores at 1.5 GHz) and 4GB RAM. The Delta has a Celeron N4100 (4 cores at 1.1 GHz / up to 2.4 GHz burst) and 4GB RAM.
I'm planning on ordering one once they start shipping, and probably adding a larger M.2 SSD drive to run as the system drive.
I haven't been able to find anything with more power per square inch and per watt, and $198 with Win10 Pro is pretty amazing considering how much the Win Pro license would cost you for a barebones build.
The possibility for expansion down the road via touch display and arduino inputs/outputs is interesting too if you're the tinkering type.
HTML code is On
LattePanda Win 10 Mini Computer doctorpd HS3 / HS3PRO Discussion 1 December 24th, 2015 05:17 PM
CC Development boards stevepyle HomeSeer Current Cost Envi Plug-in 2 September 4th, 2010 03:16 PM
Advantech I/O Boards wallebalboa General Home Automation Hardware Discussion 4 November 13th, 2009 01:11 AM
Weeder IO boards Barry Gordon Plug-In Development 1 July 18th, 2007 10:44 AM
Hobby Boards and USB english_1969 MCS Temperature 7 May 14th, 2006 09:10 PM
