I am new to Homeseer, another ex Vera user who got frustrated at the stability. Having Imperihome available helped sway my decision as the main interface will stay the same.
Having frustrating issues with the initial connection and getting
Error Invalid response from API
Can connect to URL from device, and get blank screen.
My Environment:
HomeSeer Version: HS3 Standard Edition 3.0.0.368 (Linux) (on Ubuntu 16.04)
ImperiHome plugin version 3.0.0.25
ImperiHome v4.0.7
Setup "log to file" at Trace level, and getting the following error, when I try to do initial connection:
Apr-11 17:00:40 INFO ImperiHome version 3.0.0.25
Apr-11 17:00:41 DEBUG Start building cache
Apr-11 17:00:41 DEBUG HS ISS server started:
Apr-11 17:00:42 DEBUG End building cache
Apr-11 17:01:33 TRACE ISSServer Request: /issapi/system
Apr-11 17:01:33 ERROR System.IO.FileNotFoundException: Could not load file or assembly or one of its dependencies.
File name: 'System.Xml.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'
at Newtonsoft.Json.JsonSerializer.GetMatchingConverter (IList`1 converters, System.Type objectType) <0x40322910 + 0x00054> in <filename unknown>:0
at Newtonsoft.Json.Serialization.DefaultContractResolver.Initia lizeContract (Newtonsoft.Json.Serialization.JsonContract contract) <0x40321c80 + 0x00157> in <filename unknown>:0
at Newtonsoft.Json.Serialization.DefaultContractResolver.Create ObjectContract (System.Type objectType) <0x40320fc0 + 0x0006b> in <filename unknown>:0
at Newtonsoft.Json.Serialization.DefaultContractResolver.Create Contract (System.Type objectType) <0x4031b370 + 0x0028f> in <filename unknown>:0
at Newtonsoft.Json.Serialization.DefaultContractResolver.Resolv eContract (System.Type type) <0x4031b000 + 0x00144> in <filename unknown>:0
at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.G etContractSafe (System.Object value) <0x4031aec0 + 0x00042> in <filename unknown>:0
at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.S erialize (Newtonsoft.Json.JsonWriter jsonWriter, System.Object value, System.Type objectType) <0x4031ac00 + 0x000e7> in <filename unknown>:0
at Newtonsoft.Json.JsonSerializer.SerializeInternal (Newtonsoft.Json.JsonWriter jsonWriter, System.Object value, System.Type objectType) <0x4031a150 + 0x005df> in <filename unknown>:0
at Newtonsoft.Json.JsonSerializer.Serialize (Newtonsoft.Json.JsonWriter jsonWriter, System.Object value, System.Type objectType) <0x4031a120 + 0x00020> in <filename unknown>:0
at Newtonsoft.Json.JsonConvert.SerializeObjectInternal (System.Object value, System.Type type, Newtonsoft.Json.JsonSerializer jsonSerializer) <0x40315a40 + 0x00113> in <filename unknown>:0
at Newtonsoft.Json.JsonConvert.SerializeObject (System.Object value, System.Type type, Newtonsoft.Json.JsonSerializerSettings settings) <0x40314430 + 0x0002f> in <filename unknown>:0
at Newtonsoft.Json.JsonConvert.SerializeObject (System.Object value) <0x40314350 + 0x00013> in <filename unknown>:0
at HSPI_ImperiHome.ISSServer.HandleRequest (System.String absolutePath) <0x40313d30 + 0x000cb> in <filename unknown>:0
Apr-11 17:02:41 DEBUG Device 772 value changed from 11.068 to 11.093
When I ssh onto server, I find the following Newtonsoft.Json.dll files.
root@homeseer1:/opt/HomeSeer# find . | grep -i Newtonsoft.Json
./Updates3/ImperiHome3.0.0.25/Newtonsoft.Json.dll
./bin/Z-Wave/Newtonsoft.Json.dll-prev
./bin/homeseer/Newtonsoft.Json.dll
./bin/ImperiHome/Newtonsoft.Json.dll
Any thing I should try here ? Have reinstalled plugin multiple times. Tried custom http server, disabled firewalls, multiple iOS and Android devices.
I had this working on the hs3-pi version with no issue while I was evaluating, but moved to HS3 Full, when I setup permanently.
Cheers
My Environment:
ImperiHome v4.0.7
Cheers
