I'm not exactly sure when this started happening because I started installing a few Insteon devices about the same time I updated to HS 2.?? with .NET2. Currently running 2.2.0.10.
Since around that time, HS refuses to receive responses from my RCS TXB16 thermostat. I'm pretty sure it worked about 90% of the time before I started tinkering. I have two SH BoosterLincs and have moved them around trying various combinations, some that don't even make sense. It looks like I can send commands without issue no matter where the BoosterLincs are.
This is new construction. My heater is on a single "home-run" from the B side of the breaker panel and my HS box is on the A side. I have a SH Signal Linc coupler/repeater at the dryer outlet which seems to work fine for everything else.
I have a second TXB16 that I've hesitated to install in the upstairs zone until I was very sure this was a bit closer to 100%. Glad I didn't, so far.
I'm now seeing that poor Jim seems to have given up on the RCS plugin, and I'm not prepard to hack at the code to get this working.
Can anyone think of something I can test for or am failing to see?
- - PLEASE let me know if I should take this to a different forum. I only posted here because of the apparent coincidence. ---
