I've been browsing the threads related to virtual devices for some time now but can't quite find what I'm after. I'm wondering if it's even possible without scripting.
I'm trying to create a simple virtual device that I can use as a countdown timer in HSTouch. To that end I'm trying to create a dimmable virtual device with range of 0-30 so that I could use the dim value as the timer display
Basically something like this
Turn virtual device on - setting it to 30
start a recurring event every minute that sends a dim command to the device
When the device hits off - hitting 0 it will turn back on to 30 and start again.
I can create the device but I can't seem to set up a control for it that will just allow me to send it a dim command that decreases its value by one. I end up with scales or dropdowns to set the value and that's not much use to me.
Is there such a thing as a control to just 'bump' the virtual device up or down by 'one'?
I see many of my devices that have a -6 and -7 for dim and bright commands but I don't see how they're implemented - I'm assuming that they're used as event triggers?
