MNSandler HS3 Insteon Plug-In Version 3.0.6.0 Release (Windows & Linux)
    something isn't right. the devices should look like the following and align by name and address number (1...5)
    Mark
    HS3 Pro 4.2.19.5
      I thought the icons seemed backwards. Any idea for a solution?
        Just updated to 3.0.6.0 ... (HS3 Pro / Windows)
        1) Broke all Insteon Leak Sensor Heartbeat links in my Events.
        2) The status text in HS Designer for all door/window sensors are initially blank (in the client). If I toggle (open/close) a sensor with the client open, it updates and displays that location correctly. If I close and re-open the client, all sensor status text fields are blank again.
          did you add the RecreateDevices=1 to your insteon.ini [config] section, before restarting the plugin.
          if you already did this, then delete the leak sensor from the plugin, and add it again.
          Mark
          HS3 Pro 4.2.19.5
            bump
              #21
              delete just the hs devices that are incorrect, add RecreateDevice=1 to the [device x] section of the insteon.ini and restart the plugin.
              this should rebuild those hs devices.
              Mark
              HS3 Pro 4.2.19.5
                #22
                That seems to have fixed the problem. Thanks!
                  #23
                  Hi Mark,
                  I did add the statement to the config section of the insteon.ini file.
                  It was easier to just re-link the events for the leak sensors. I only have 9 leak sensors so that was a quick fix.
                  The door & window sensors are a much larger issue for me. I tried deleting one window sensors and re-installing it. No luck. The status icon is working and the status value is correct; however, the status text is still blank both in the HS Designer application and on the client (iPhone).
                    #24
                    Hi Mark,
                    i'll check this out
                    Mark
                    HS3 Pro 4.2.19.5
                      #25
                      Hi Mark,
                      I have been researching this issue. I found a post where mrhappy said the following:
                      It is likely to be because it is set up as a root device, unfortunately HSTouch I understand does not show root devices and only child devices. This was never documented to my knowledge so some plugins that use root devices to show information are not shown in HSTouch. There is nothing you can do about it really unless HSTouch or the plugin is changed.
                      My devices all displayed the status text both in HS Designer and on the client before I upgraded to V3.0.6.0 Immediately after the update, the status text disappeared. Did they change from children to root devices?
                      Also note that the status text for the Heartbeat signals display correctly for all of these devices in HS Designer & client.
                      Thank You
                        #26
                        Hi Mark,
                        Thank You
                        I did not change the root/child relationships. you can see this info on the Advanced tab of the hs device.
                        can you post the Status Graphics tab of one of the devices that you are referring to
                        Mark
                        HS3 Pro 4.2.19.5
                          #27
                          Hey Mark,
                          Here is one:
                            #28
                            Hi Mark,
                            I looked at the Advanced tab per your post. Here is the Door's Status device:
                            https://board.homeseer.com/attachmen...1&d=1486180550
                            It says parent root.
                            Here is the Advanced tab for the Heartbeat device for the same door sensor:
                            https://board.homeseer.com/attachmen...1&d=1486180644
                            This one says child .
                            One more piece to the puzzle... While the client is open, if I physically change the door position, the status text for that door (only) will update correctly on the client. If I close and re-open the client, the status text is gone.
                              #29
                              the images for the advanced tab didn't show, but the setup is correct. the heartbeat is a child of the main open/close device
                              not sure about the hstouch issue. that is a separate plugin.
                              does the status text update correctly on the hs ui?
                              Mark
                              HS3 Pro 4.2.19.5
                                #30
                                Here are the Advanced tab images:
                                The status text does update correctly on the hs ui.
