good deal. if the links reappear,then from the config page please generate a support log, and see if you can find any evidence that the plugin recreated the links
Random 'All Lights On' Anomaly
Mark
HS3 Pro 4.2.19.5
The bad links did not recreate themselves until I refreshed the device links on the Manage Devices page. After I selected 'Update programing on all new and updated devices', the Bad Link Entry, unreferenced group # messages reappeared.
One thing I noticed prior to performing this action is that on the Main Insteon Configuration Page the "You have 254 unused outbound link addresses out of 254 total available" stated that there were 214 unused outbound links, which I'd never seen before. It was always as it states above.
Where do I post the Insteon Error Report.log file? It won't upload in the file attachment section.
Originally posted by Bill Grant View PostThe bad links did not recreate themselves until I refreshed the device links on the Manage Devices page. After I selected 'Update programing on all new and updated devices', the Bad Link Entry, unreferenced group # messages reappeared.
the outbound info captures links from the plm to KPLs, groups, etc. Its just for reference.Mark
HS3 Pro 4.2.19.5
can you enabled detailed logging on the plugin config page, and then run the 'program device for homeseer' on the following device within the plugin:
[Device 4]
DeviceID=0C.F0.8C
DeviceName=Floor Lamp (Front Door)
DeviceLocation=Hall
if the bogus link gets created, then post the log snippet for the programming transactionMark
HS3 Pro 4.2.19.5
I did what you said and the bogus links were not recreated.
While deleting the bad link entries, I noticed that they all existed within KPL devices, of which I have four that function (plus one dead one that won't communicate but still have local control). Three of the working KPLs had the rogue links and one did not.
There is a common denominator which I am now wondering if it's the cause. The KPL that does not have bad links has control over several buttons on the other three KPLs. I did this for syncing purposes originally.
Here is the link table from the KPL that has no bogus links.
Device Link Table
Link #1 Button H controls Family Room Keypad Ceiling Pot Lights (42.15.AC)
Link #2 Button C has local control reporting to HomeSeer
Link #3 Button D has local control reporting to HomeSeer
Link #4 Button E has local control reporting to HomeSeer
Link #5 Button A/Load has local control reporting to HomeSeer
Link #6 Button F has local control reporting to HomeSeer
Link #7 Button H has local control reporting to HomeSeer
Link #8 Button A/Load is controlled by HomeSeer using RF PLM Group #254 (HomeSeer All Devices Group) - On Level: 100%, Ramp Rate: .1 Sec.
Link #9 Button H is controlled by Family Room Keypad Ceiling Pot Lights Button A/Load (42.15.AC) - On Level : On
Link #10 Button B has local control reporting to HomeSeer
Link #11 Button G has local control reporting to HomeSeer
Link #12 Button E controls Mudroom Keypad Ceiling & Wall Lights Button E (42.15.20)
Link #13 Button E is controlled by Mudroom Keypad Ceiling & Wall Lights Button E (42.15.20) - On Level : On
Link #14 Button E controls Sewing Room Ceiling Lights (0D.AC.40)
Link #15 Button E is controlled by Sewing Room Ceiling Lights (0D.AC.40) - On Level : On
Link #16 Button E controls Sewing Room Ceiling Lights (slave) (0D.AC.E0)
Link #17 Button E is controlled by Sewing Room Ceiling Lights (slave) (0D.AC.E0) - On Level : On
Link #18 Button E controls Sewing Room Ceiling Lights (slave) (0D.BC.6F)
Link #19 Button E is controlled by Sewing Room Ceiling Lights (slave) (0D.BC.6F) - On Level : On
Link #20 Button E controls Bedrooms Ceiling Lights (0D.A3.DE)
Link #21 Button E controls Hall Ceiling Lights (0D.AB.A6)
Link #22 Button E controls Hall Lights (slave) (0D.B9.F5)
Link #23 Button E controls Suite Entry Ceiling Lights (0D.A8.59)
Link #24 Button E is controlled by Suite Entry Ceiling Lights (0D.A8.59) - On Level : On
Link #25 Button F is controlled by Garage Left Bay Door Input Sensor (1D.5A.1E) - On Level : On
Link #26 Button G controls Garage Middle Bay Door Output Relay (1D.59.45)
Link #27 Button F controls Garage Left Bay Door Output Relay (1D.5A.1E)
Link #28 Button G is controlled by Garage Middle Bay Door Input Sensor (1D.59.45) - On Level : On
Link #29 Button H controls Family Room Keypad Ceiling Pot Lights Button B (42.15.AC)
Link #30 Button H is controlled by Family Room Keypad Ceiling Pot Lights Button B (42.15.AC) - On Level : On
Link #31 Button B controls Yard Front Lawn Flood (0D.BE.2C)
Link #32 Button B is controlled by Yard Front Lawn Flood (0D.BE.2C) - On Level : On
Link #33 Button C controls Yard Pond Flood (0D.A9.E1)
Link #34 Button C is controlled by Yard Pond Flood (0D.A9.E1) - On Level : On
Link #35 Button D controls Garage Ceiling Pot Lights (0D.A4.36)
Link #36 Button D is controlled by Garage Ceiling Pot Lights (0D.A4.36) - On Level : On
Link #37 Button H controls Family Room Desk Lamp (0C.ED.71)
Link #38 Button H is controlled by Family Room Desk Lamp (0C.ED.71) - On Level : On
Link #39 Button H controls Family Room Table Lamp (Wall) (0C.F2.9B)
Link #40 Button H is controlled by Family Room Table Lamp (Wall) (0C.F2.9B) - On Level : On
Link #41 Button H controls Family Room Table Lamp Window (0C.F0.2F)
Link #42 Button H is controlled by Family Room Table Lamp Window (0C.F0.2F) - On Level : On
Link #43 Button H controls Family Room Keypad Ceiling Pot Lights Button C (42.15.AC)
Link #44 Button H is controlled by Family Room Keypad Ceiling Pot Lights Button C (42.15.AC) - On Level : On
Link #45 Button H controls Family Room Keypad Ceiling Pot Lights Button D (42.15.AC)
Link #46 Button H is controlled by Family Room Keypad Ceiling Pot Lights Button D (42.15.AC) - On Level : On
Link #47 Button H controls Family Room Keypad Ceiling Pot Lights Button E (42.15.AC)
Link #48 Button H is controlled by Family Room Keypad Ceiling Pot Lights Button E (42.15.AC) - On Level : On
Link #49 Button H controls Family Room Keypad Ceiling Pot Lights Button F (42.15.AC)
Link #50 Button H is controlled by Family Room Keypad Ceiling Pot Lights Button F (42.15.AC) - On Level : On
Link #51 Button H controls Family Room Keypad Ceiling Pot Lights Button H (42.15.AC)
Link #52 Button H is controlled by Family Room Keypad Ceiling Pot Lights Button H (42.15.AC) - On Level : On
Link #53 Button H controls Kitchen Keypad Ceiling Pot Lights (0A.AD.2C)
Link #54 Button H is controlled by Kitchen Keypad Ceiling Pot Lights Button A/Load (0A.AD.2C) - On Level : On
Link #55 Button H controls Kitchen Keypad Ceiling Pot Lights Button B (0A.AD.2C)
Link #56 Button H is controlled by Kitchen Keypad Ceiling Pot Lights Button B (0A.AD.2C) - On Level : On
Link #57 Button H controls Kitchen Keypad Ceiling Pot Lights Button C (0A.AD.2C)
Link #58 Button H is controlled by Kitchen Keypad Ceiling Pot Lights Button C (0A.AD.2C) - On Level : On
Link #59 Button H controls Kitchen Keypad Ceiling Pot Lights Button D (0A.AD.2C)
Link #60 Button H is controlled by Kitchen Keypad Ceiling Pot Lights Button D (0A.AD.2C) - On Level : On
Link #61 Button H controls Kitchen Keypad Ceiling Pot Lights Button E (0A.AD.2C)
Link #62 Button H is controlled by Kitchen Keypad Ceiling Pot Lights Button E (0A.AD.2C) - On Level : On
Link #63 Button H controls Kitchen Keypad Ceiling Pot Lights Button F (0A.AD.2C)
Link #64 Button H is controlled by Kitchen Keypad Ceiling Pot Lights Button F (0A.AD.2C) - On Level : On
Link #65 Button H controls Kitchen Keypad Ceiling Pot Lights Button G (0A.AD.2C)
Link #66 Button H is controlled by Kitchen Keypad Ceiling Pot Lights Button G (0A.AD.2C) - On Level : On
Link #67 Button H controls Kitchen Keypad Ceiling Pot Lights Button H (0A.AD.2C)
Link #68 Button H is controlled by Kitchen Keypad Ceiling Pot Lights Button H (0A.AD.2C) - On Level : On
Link #69 Button H controls Dining Room Floor Lamp (0C.F3.3E)
Link #70 Button H is controlled by Dining Room Floor Lamp (0C.F3.3E) - On Level : On
Link #71 Button H controls Dining Room Hutch Lamp (0C.ED.7F)
Link #72 Button H is controlled by Dining Room Hutch Lamp (0C.ED.7F) - On Level : On
Link #73 Button H controls Dining Room Table Lamp (0C.EC.A7)
Link #74 Button H is controlled by Dining Room Table Lamp (0C.EC.A7) - On Level : On
Link #75 Button H controls Eating Nook Table Lamp (0C.ED.EC)
Link #76 Button H is controlled by Eating Nook Table Lamp (0C.ED.EC) - On Level : On
Link #77 Button H controls Hall Floor Lamp (Front Door) (0C.F0.8C)
Link #78 Button H is controlled by Hall Floor Lamp (Front Door) (0C.F0.8C) - On Level : On
Link #79 Button H controls Hall Table Lamp (0C.F0.62)
Link #80 Button H is controlled by Hall Table Lamp (0C.F0.62) - On Level : On
Link #81 Button H controls Kitchen Counter Light Left of Fridge (12.58.47)
Link #82 Button H is controlled by Kitchen Counter Light Left of Fridge (12.58.47) - On Level : On
Link #83 Button H controls Kitchen Counter Lights Behind Deck Door (0D.C0.E5)
Link #84 Button H is controlled by Kitchen Counter Lights Behind Deck Door (0D.C0.E5) - On Level : On
Link #85 Button H controls Kitchen Counter Lights Left of Range (0D.C0.BF)
Link #86 Button H is controlled by Kitchen Counter Lights Left of Range (0D.C0.BF) - On Level : On
Link #87 Button H controls Kitchen Counter Lights Right of Range (12.5E.70)
Link #88 Button H is controlled by Kitchen Counter Lights Right of Range (12.5E.70) - On Level : On
Link #89 Button H controls Kitchen Lights (Slave) (0D.A4.CB)
Link #90 Button H is controlled by Kitchen Lights (Slave) (0D.A4.CB) - On Level : On
Link #91 Button H controls Kitchen Lights (Slave) (0D.BF.0E)
Link #92 Button H is controlled by Kitchen Lights (Slave) (0D.BF.0E) - On Level : On
Link #93 Button H controls Living Room Display Lighting (1D.30.7E)
Link #94 Button H is controlled by Living Room Display Lighting (1D.30.7E) - On Level : On
Link #95 Button H controls Living Room Table Lamp (Wall) (0C.EE.E7)
Link #96 Button H is controlled by Living Room Table Lamp (Wall) (0C.EE.E7) - On Level : On
Link #97 Button H controls Living Room Table Lamp (Window) (0C.F0.33)
Link #98 Button H is controlled by Living Room Table Lamp (Window) (0C.F0.33) - On Level : On
Link #99 Button H controls Office Table Lamp (0C.F1.44)
Link #100 Button H is controlled by Office Table Lamp (0C.F1.44) - On Level : On
Link #101 Button H controls Mudroom Keypad Ceiling & Wall Lights (42.15.20)
Link #102 Button H is controlled by Mudroom Keypad Ceiling & Wall Lights Button A/Load (42.15.20) - On Level : On
Link #103 Button H controls Eating Nook Ceiling Light (12.50.DF)
Link #104 Button H is controlled by Eating Nook Ceiling Light (12.50.DF) - On Level : On
Bill,
I think you are onto something, but the unregistered links are related to the plm id which is confusing. links between kpls won't have the plm id within the data.
please delete the [group 0] section in the insteon.ini. maybe the plugin is trying to rebuild links for this.Mark
HS3 Pro 4.2.19.5
Mark, I don't see a [Group 0] entry in insteon.ini. Please advise.
I'm going to delete all those inter-button links and see if that fixes it. I want to create groups anyway. I'm just wondering about button/device status syncing. It doesn't seem to work well with device status change by event or manually; perhaps it will if the responder buttons are controlled by grouping. ??
Originally posted by Bill Grant View PostMark, I don't see a [Group 0] entry in insteon.ini. Please advise.
the plugin attempts to sync hs devices when it receives inbound insteon msgs, and when the plugin transmits a message.
please post a pic of the event that the plugin are having trouble syncing the hs devices when run. I'll see if the scenario is covered.Mark
HS3 Pro 4.2.19.5
Hey
this is very similar to what i had a year ago.
it happened almost every night at 3-4 am were all my devices in the house turned on at once.
i mean everything.... projector screen and elevator, all the shades, lights .....
i found out that the UPS that i connected my homeseer computer and ADSL router was very near the HUB (on the other side of the network cupboard but still).
i am guessing it made the HUB send a "full on " frantic..
hope this helps
Originally posted by Bill Grant View PostI would like to have a go at deleting the 'Global Insteon' "device", but I'm a bit chickens**t. I don't want to do any more damage than I've already done, if you know what I mean.
the global link will be recreated the next time you reprogram the device.Mark
HS3 Pro 4.2.19.5
