Insteon 2413U with MSandler Installation
    I'm not sure if this post will make it through however I need to get a procedure for installing a Insteon 2413 USB onto a HS3 HST Zee S2. I now familiar with bulletin Boards nor a real fan however it is what it is I just need this working and with only a few days left before the MS Insteon Plug In expires and I move onto Z-Wave alternatives. I would really like it to work.
    That being said after installing the PlugIn and then pluging in a 2413 USB from Insteon Store I cannot get the Zee S2 Hometroller to recognize the 2413. HELP.
    I've installed an Insteon 2413 USB on a S6 Hometroller S6 and it went rather smoothly but then again that was a Windows based system and this is and the Zee S2 I think is a Lynx based system.
    Welcome.
    for a Linux based system, use the something like following for the Port name:
    /dev/ttyUSB0 is USB
    /dev/ttyUSB1 is USB, etc.
    You need to know which usb port the PLM is connected to.
    ps. I moved your post to a new thread, you had originally replied to the Feature Request thread.
    Mark
    HS3 Pro 4.2.19.5
