Can I just shut off X10 debug?
    Response times have been well here and I would like to shut off debug in the X10 plugin. IE: I do not need to watch any more.
    Is there a way to do this without shutting off general developer mode check box?
    Auto mator
    Yes, the logging of debug messages by the X10 plugin can be manually configured using 2 entries in X10.ini under [settings]: 'Override' and 'PluginDebug'.
    Override=False: plugin uses Developer Mode' setting in HS (Developer Mode enabled = log debug messages, Developer Mode disabled = don't log debug messages)
    Override=True: plugin uses 'PluginDebug' setting in ini (ignore Developer Mode setting in HS)
    PluginDebug=False: plugin will not log debug info (only valid when Override=True)
    PluginDebug=True: plugin will log debug info (only valid when Override=True)
    Note that you must restart the plugin after changing these entries in order for the changes to take effect.
    Thanks for your help testing and sorting out Gordon's issue!
    Best regards,
    -Mark-
    If you're not out on the edge, you're taking up too much room!
    Interested in 3D maps? Check out my company site: Solid Terrain Modeling
      Thank you Mark.
      Disabled Plugin.
      Edited ini file to read as follows:
      [settings]
      PluginDebug=False
      Override=True
      [Default]
      Protocol=0
      PollInterval=300
      enabled plugin.
      Auto mator
        Any time Sir!
        Best regards,
        -Mark-
