Here are the instructions for installing the EZFlora Plugin.
Note: Do not register your EZFlora directly with the Insteon plugin. Device registration will be done automatically by the EZFlora plugin. Registering the device directly with the Insteon plugin will cause the EZFlora plugin to not function proplery.
Please let me know if you have any questions or need any help.
Adam
- From the updater download the EZFlora plugin
- Delete any EZFlora devices and shutdown HomeSeer
- Remove any EZFlora scripts from the \scripts folder
- Restart Homeseer and the plugin will automatically install
- Within Homeseer, go to the "Setup" tab and then interfaces and enable the EZFlora plugin and then click save. Upon saving the EZFlora plugin will become active.
- Click on the "EZFlora Configuration" link and click on the "Add Device" link.
- Enter the device parameters and click submit.
- When you return to your status page, all devices should be populated.
- The root device will allow you to enable/disable diagnostic mode (cycles through each valve in one second intervals).
- Each valve can be individually enabled or disabled (only one valve can be active at a time)
- Each program can be enabled/disabled and when a program is running you can use the next/previous buttions to the move the next/previous valve in the program (EZFlora programs must be programmed externally using the SimpleHomeNet Utility)
- The Rain Sensor status will show on if rain is detected and off if rain is not detected
- The Meter Count will reflect the meter count of the EZFlora if Meter is checked in the configuration. There is a reset button on the meter count to reset the count to "0".
Adam
