  #101
Old July 5th, 2012, 10:07 PM
pcp pcp is offline
Super Seer
Just posted an updated beta version resolving a few issues.
  #102
Old July 30th, 2012, 02:55 PM
remcoploeg remcoploeg is offline
I have used this plugin now for 2 months working fine. But since today my music was not working anymore. After a reboot still no luck. So I opened HStouch designer to select my Music Browser. The basic music browser don't see any player anymore. In the plugin configuration I still see my player. I can still control my squeezebox via the devices. What can be wrong that I don't see it anymore in HStouch music browser? My logitech software was started first, than HStouchPro...
I have run the script I have received in the beginning and see a lot of info, here some samples:
Index 3 : Winter (Nuspirit Helsinki Reinterpretation)
30-7-2012 21:22:13 Music API Index 2 : Aganjú (Latin Project Mix)
30-7-2012 21:22:13 Music API Index 1 : O Caminho (Guy Sigsworth Mix)
30-7-2012 21:22:13 Music API Index 0 : Simplesmente (Tom Moddleton Cosmos Mix)
30-7-2012 21:22:13 Music API Current PLaylist Track Count: 500
30-7-2012 21:22:00 Music API --- Current Playlist ----
30-7-2012 21:22:00 Music API Instance Number: 1
30-7-2012 21:22:00 Music API Instance Name: Squeezebox Radio
30-7-2012 21:22:00 Music API Number of instances: 3
30-7-2012 21:22:00 Music API Found plugin SqueezeBox
30-7-2012 21:22:00 Event Running script in background: test_sb_music_api2.vb
The strange thing I have only one squeezebox..
I am running version 2.1.0.7 of squeezebox plugin
HStouch pro latest version
HSTouch 1.0.72
thanks in advance,
Remco
  #103
Old July 31st, 2012, 03:02 PM
w.vuyk's Avatar
w.vuyk w.vuyk is offline
Originally Posted by w.vuyk View Post
Phillipe,
in the log I am playing a static list to exclude confusion of dynamic lists.
Wim
Phillipe,
Were you able to find what is wrong with the speech in my log?
Also lately the error on "CurrentTrackTimeValue" is occurring every time in the HS log I play music with the LMS. I wonder where this could be coming from?
Wim
-- Wim
Plugins:RFXCOM, HSTouch Server, Squeezebox, BLGData, Restart, Jon00's Perfmon and Network monitor, WeatherXML, BLBackup, TenScripting, BC4, Pushover, PHLocation, JowiHue, Zwave, Sonos
650 devices ---- 336 events ----- 40 scripts
  #104
Old July 31st, 2012, 09:29 PM
pcp pcp is offline
Super Seer
I haven't been able to determine anything in terms of returning to the random/dynamic song. I don't recall if the LMS was regenerating the playlist of not, its been a while. Are you using the latest beta version that supports the dynamic playlists?
  #105
Old July 31st, 2012, 09:33 PM
pcp pcp is offline
Super Seer
Originally Posted by remcoploeg View Post
HSTouch 1.0.72
thanks in advance,
Remco
I fixed an issue in a subsequent beta version (beta 8 and 9) that might be related to the behavior you see. can you try the latest beta version 11(http://board.homeseer.com/showpost.p...&postcount=1)?
  #106
Old August 1st, 2012, 01:36 AM
w.vuyk's Avatar
Philippe,
For the test with speech I was using a static playlist to be sure it was not dynamic playlists causing this. For me speech does not work without skipping to a next song. It does not matter if I am using static or dynamic lists.
I am using the latest plugin with the dynamic playlist. Did not work a lot with it yet though (as in changing my alarm to musicapi usage only). This is because I moved LMS to a NAS, instead of running on my windows machine. This did not change my speech issue, instead the occurance of errors increased.
1-8-2012 7:16:35 SqueezeBox Error An unexpected error occured in the CurrentTrackTimeValue: 91.2267270774841 function/subroutine: [System.OverflowException: De rekenkundige bewerking heeft geresulteerd in een overloop. bij Microsoft.VisualBasic.CompilerServices.Conversions.ToInteger (String Value) bij HSPI_SQUEEZEBOX.hspi_player.get_CurrentTrackTimeValue()]
This occurs every 30 seconds 3 times, as I have 3 devices connected and 3 disconnected. I guess it is some polling issue?
Wim
  #107
Old August 2nd, 2012, 09:52 AM
I have updated the version but no luck. Still no players within hstouch. Any other idea?
thanks in advance!
Remco
  #108
Old August 3rd, 2012, 02:16 PM
Raptor's Avatar
Raptor Raptor is offline
i was having issues with this too, what version of the squeezebox server/Logitech media server are you using?
HS3 Pro on Windows 8 64bit
53 Z-wave nodes(46 devices, 7 remotes), 15 DS10a's, 10 ms16a's, 9 Oregon Sensors, W800, RFXCOMtrx433, Way2Call, 3 HSTouch Clients, 2xRussound CAS44, Global Cache GC100-12,10 Rollertrol blinds(+ zwave) ,3 Squeezebox Radios and 1 Squeezebox Boom,DMX Arduino via ethernet,Rain8Net,3x Echo Dot's
Check out my electronics blog here:
https://www.facebook.com/RaptorsIrrationalInventions
  #109
Old August 5th, 2012, 02:15 PM
pcp pcp is offline
Super Seer
Philippe,
Wim
I will look into it. Unfortunately got back from traveling to find that HS2 server died and running into issues with my development server as well. Gone have to fix both first!
  #110
Old August 5th, 2012, 02:22 PM
pcp pcp is offline
Super Seer
thanks in advance!
Remco
Just curious, did you start LMS and connect the players prior to starting HS2? Check in the plugin ini file, there should be entries per player number to give the default player name used at startup (prior to receiving the player names from LMS). If you enable debugging + verbose debugging for the plugin, I can look at the log to see if can determine anything.
  #111
Old August 19th, 2012, 11:33 AM
pcp pcp is offline
Super Seer
I just posted a beta 12 and should resolve this. Give it a try. Thanks.
  #112
Old August 26th, 2012, 05:12 PM
w.vuyk's Avatar
Phillipe,
Saw your message just now. Will give it a try right away. Hope to come back to you tmorrow or Tuesday.
Wim
  #113
Old August 28th, 2012, 04:52 PM
w.vuyk's Avatar
Thumbs up
Phillipe,
Wim
Philippe,
I have a clean log again!
Could this be of influence of my speech problems maybe? Because in that case I will try to setup speech up again this weekend and test it. I would like to be able to use the speech over the squeezeboxes since my other speech is now only possible in the livingroom and I would like it to speak upstairs too.
Wim
  #114
Old September 8th, 2012, 11:22 AM
pcp pcp is offline
Super Seer
This version is now available via the Updater.
  #115
Old September 10th, 2012, 03:02 PM
depampi depampi is offline
I want to create a button that selects spotify entries in the music selector. To do so I've created the following actions for the button:
1 Music: Set music selector display, with selector display genres
2 Elements: apply a display filter: LMS*
This works but if I then select LMS_MyApps -> Spotify, the list is empty. When I manual browse to this path, it does work.
How can I solve this?
Best regards
De Pampi
  #116
Old September 10th, 2012, 07:40 PM
pcp pcp is offline
Super Seer
I haven't tried this and not sure how the HSTouch view filter works, but could it be that your filter still applies once you selected Spotify and since none will start with LMS it filters all out?
  #117
Old September 15th, 2012, 04:29 AM
Hi When I try to run the Spofify app on hstouch, the whole hstouch screens holds. Beside of that I see in my logging (don't known if that is spotifiy by the way) this:
an unexpected error occured in the CurrentTrackTimeValue: 120.406558174133 function/subroutine: [System.OverflowException: Arithmetic operation resulted in an overflow. at Microsoft.VisualBasic.CompilerServices.Conversions.ToInteger (String Value) at HSPI_SQUEEZEBOX.hspi_player.get_CurrentTrackTimeValue()]
Any ideas?
thanks
  #118
Old September 15th, 2012, 12:50 PM
pcp pcp is offline
Super Seer
Are you running the latest version of the plugin from Updater?
  #119
Old October 30th, 2012, 04:28 AM
Moskus's Avatar
Moskus Moskus is offline
pcp, do you think there could be some connection between HStouch errors, HS locking up and your Squeezebox plugin?
HSPro 3.0.0.435, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
  #120
Old October 31st, 2012, 08:22 AM
pcp pcp is offline
Super Seer
I am looking into it but might take some time. The strange thing is that yesterday after upgrading to HSTouch .60 from .59 (via the updater) and with the SB plugin disconnected from LMS, HS2Pro would not shutdown properly. It was stuck after the message shutting down threads. This occurred multiple times.
HTML code is On
