  #61
Old October 31st, 2016, 08:27 AM
pcp pcp is offline
Super Seer
Thanks. The plugin uses the HS3 scripting API SpeakToFile to generate the audio file to be spoken, then uses the lame app included in HS3 to generate an MP3 file and both of these will control the format of the generated audio file. The selected voice used by the SpeakToFileAPI and the lame arguments which are specified in the SqueezeBox plugin configuration are critical to format of the generated audio file (frequency, sampling, etc) as done in the prior post.
  #62
Old December 2nd, 2016, 06:26 AM
Yoja Yoja is offline
lame options
added:
-f -b128
to TTS MP3 Lame options in the Speak Proxy tab.
Now playing speech with PiCorePlayer. Sometimes response is slow.
Need some more testing, at least I have sound :-)
update: max2play does not work :-(
  #63
Old January 26th, 2017, 12:09 PM
slow response
TTS works for all the rapsberry pi max2play devices.
(I set Streaming Method in LMS to Proxied Streaming)
The strange thing is, the response when speaking is sometimes very slow.
Does anyone have a clue why? I really like this plugin, This is the only thing that I can't get working properly.
yoja
  #64
Old January 26th, 2017, 08:57 PM
pcp pcp is offline
Super Seer
Originally Posted by Yoja View Post
yoja
Try to locate the mp3 file that is generated in h3 html then in squeezebox plugin filder and play it a media player to ser if sliw as well.
HTML code is On
SqueezeBox plugin V3.x for HS3 pcp SqueezeBox Plug-In (3P) 171 August 10th, 2017 07:41 AM
Squeezebox plug-in for HS2 won't work risquare SqueezeBox Plug-In (3P) 1 November 27th, 2014 07:47 AM
SqueezeBox plugin V2.1.0 beta pcp SqueezeBox Plug-In (3P) 138 January 30th, 2013 08:39 AM
SqueezeBox plugin V1.6.0 beta 1 available pcp SqueezeBox Plug-In (3P) 3 February 24th, 2009 11:18 PM
HS Touch Samples that Work with SqueezeBox Player/Rxr smilligan SqueezeBox Plug-In (3P) 3 February 9th, 2009 08:46 AM
