Old October 15th, 2016, 04:29 PM
stvjfp1 stvjfp1 is offline
Line in on Boom
I would like to control my Line in a Boom, that is turn it on/off, any suggestion’s?
Old October 23rd, 2016, 11:13 AM
pcp pcp is offline
Super Seer
There is not plugin function for this, though you can use the plugin PlayerSendCLICommand command in HS3 (see plugin doc) to send the Squeezebox CLI command for the Boom if any to switch the input line (not sure what that CLI command is)
Old October 23rd, 2016, 11:51 AM
sparkman's Avatar
sparkman sparkman is offline
As an FYI, you need to enable the Line In plugin in LMS for the Boom to have the ability to control it. Supposedly the cli command to turn it on is
00:04:20:xx:yy:zz setlinein linein
but I haven't tried this myself and I don't know what the command is to turn it off. It may automatically turn off if you start playing a regular source.
Cheers
Al
Old October 31st, 2016, 08:07 AM
pcp pcp is offline
Super Seer
The script would be something line though have not tested it. playerInstance needs to be the instance of the Boom player. You can find the instance in the SqueezeBox > Status page.
PHP Code:
Sub Main(Parm As Object)
  Try
Dim playerInstance As String "Player_0015833d0a57"
Dim Args(1) As Object
    Args
(0) = "setlinein linein"
Args(1) = False
    hs
.PluginFunction("SqueezeBox"playerInstance"PlayerSendCLICommand"Args)
  Catch
ex As Exception
    hs
.WriteLog("SqueezeBox Scripts""Exception " ex.ToString)
End Try
End Sub
Old October 31st, 2016, 03:06 PM
Thank you, the script worked.
HTML code is On
"failed to parse" on squeezebox BOOM extra menu psampson SqueezeBox Plug-In (3P) 10 October 18th, 2009 08:18 PM
Flood cam go boom?? drozwood90 Electronic Circuits and Hardware Modifications 8 August 18th, 2009 02:10 PM
Where does it line up? drozwood90 PowerTrigger Plug-In 0 December 8th, 2008 11:49 AM
220v APC battery backup (things go boom!) John_Dula General Home Automation Hardware Discussion 5 April 14th, 2005 02:32 AM
