Just installed from the updater and get the following error:
May-10 11:29:19 PM SonyAVR ERROR PollAVR Request has timed out
May-10 11:28:19 PM SonyAVR ERROR PollAVR Request has timed out
May-10 11:27:19 PM SonyAVR ERROR PollAVR Request has timed out
May-10 11:26:19 PM SonyAVR ERROR PollAVR Request has timed out
May-10 11:25:13 PM SonyAVR ERROR System.Exception: Request has timed out at SonyAVR.Net.SonyAVRClient.SendRequest(JObject jobject, Int32 timeoutInMs) at SonyAVR.Net.SonyAVRClient.GetFeature(String feature) at HSPI_SonyAVR.SonyAVRApp.InitSonyAVRClient()
May-10 11:25:08 PM SonyAVR INFO Initializing SonyAVR Client
May-10 11:25:08 PM Plug-In Finished initializing plug-in SonyAVR
Apart from IP address what else can I check in config? I already made sure the network options are set correctly in the AVR.
Edit: I tried shutting down the plugin and restarting it:
May-10 11:49:02 PM SonyAVR ERROR PollAVR Request has timed out
May-10 11:47:57 PM SonyAVR ERROR System.Exception: Request has timed out at SonyAVR.Net.SonyAVRClient.SendRequest(JObject jobject, Int32 timeoutInMs) at SonyAVR.Net.SonyAVRClient.GetFeature(String feature) at HSPI_SonyAVR.SonyAVRApp.InitSonyAVRClient()
May-10 11:47:53 PM Updater An item in the Updater is temporarily unavailable: The operation has timed out Item: https://dl.dropbox.com/s/s1mpzz5poizkzud/updates.txt
May-10 11:47:52 PM SonyAVR INFO Initializing SonyAVR Client
May-10 11:47:51 PM Plug-In Finished initializing plug-in SonyAVR
May-10 11:47:51 PM SonyAVR INFO SonyAVR version 3.0.0.4
May-10 11:47:51 PM Info Plugin SonyAVR has connected. IP:127.0.0.1:52877
May-10 11:47:50 PM Plug-In Interface SonyAVR is running as a trial, 30 days remaining.
May-10 11:46:37 PM Info Plugin SonyAVR with instance: has disconnected
May-10 11:46:37 PM SonyAVR INFO Shutting down SonyAVR Client
May-10 11:46:37 PM Plug-In Shutting down Plug-In: SonyAVR
May-10 11:46:19 PM SonyAVR ERROR PollAVR Request has timed out
