Greetings all,
I'm trying to install some switchlincs to replace some 3-way switches in my house.
The installation requires that I install the master switch at the load control point, and the slave switch at the other point.
How do I figure out which switch is the load control switch?
I pulled both switches out of the wall, and used a simple voltage tester on the leads on the side of each switch. Depending on which switches were on or off, I could detect voltage on either one.
If I disconnect the HOT from one switch, and the lights still work, then is that the slave switch? (Or vice-versa - if I disconnect the hot and the lights don't work is that the master?)
Or should I just disconnect the red traveller wire? Whichever switch works after that that is then the load?
Is there a better way to tell?
Steve C.
Steve C.
