Hi Bob,
I noticed over the last week that my triggers are firing once, but the speech is happening twice. I have a trigger when the front door opens to greet. It has started doubling and sometimes gives 3 greetings. The log shows firing once but the activity log in BLSpeech shows twice.
Jun-04 14:41:14 EnvisaLinkAdemco INFO Z03 Front Door status change: Closed
Jun-04 14:41:14 EnvisaLinkAdemco INFO Partition 1 status change: Ready
Jun-04 14:40:55 TTS Speak: (SPEAKEFAULT):Good afternoon. It is currently 2:40 PM and 78.3 degrees.
Jun-04 14:40:49 EnvisaLinkAdemco INFO Z08 Sitting Room Motion status change: Opened
Jun-04 14:40:49 EnvisaLinkAdemco INFO Z07 Living Room Motion status change: Opened
Jun-04 14:40:49 EnvisaLinkAdemco INFO Z03 Front Door status change: Opened
Jun-04 14:40:49 Event Event Trigger "Announcements Greeting when Front Door Opens"
6/4/2017 2:40:56 PM 0 {priority=normal,speaker=Living Room,volume=50,source=3,queue=queue}Good afternoon. It is currently 2:40 PM and 78.3 degrees. Yes SPEAKEFAULT Normal Normal Queue No
6/4/2017 2:40:41 PM 0 {priority=normal,speaker=Living Room,volume=50,source=3,queue=queue}Good afternoon. It is currently 2:40 PM and 78.3 degrees. Yes SPEAKEFAULT Normal Normal Queue No
What do you need from me? Debug log?
I have always had the option in the event set to do not repeat for 20 seconds because it would always repeat until the door shows closed. In the example above, the door closed at 14:41:14 but the speech activity shows 40:41 and again 40:56. This is less than the 20 seconds so it should not have repeated.
Since there is no second trigger to make it speak again in the log, I assume there is an issue within BLSpeech that is making it speak again.
Michael
I am using .66 version of BLSpeech
Michael
