Glad to help. Thanks for testing the latest betas and posting feedback.
Custom message script problem
Mark
HS3 Pro 4.2.19.5
Mark,
Everything seems pretty stable and working as intended. I was never able to achieve the goal if firing the script reliably once just using the custom message with the partition hack active in the panel. I ended with a two-part solution. I changed the event conditions and added a test to the virtual device that is set to 0 when the panel is armed. The script when the custom trigger is seen then sets this virtual device to on. So when the custom trigger message is bouncing from one partition to the other the condition won't be true and the script won't re-trigger until I set the virtual device to off. So all is good.
On a dumb question. You zinged (no worries and I am grateful you take the time) me on my code for my ifs in the for next loop and pointed out a more elegant method. Aside from butcher rick (which I am) is there any real benefit to be gained on a twice and done loop?
Code:sub main() hs.writelog "Alarm Tripped","The Script has been initiated." if hs.DeviceValue(566) = 0 then hs.SetDeviceValueByRef 566,1,True ' we don't want this script to rerun for x = 1 to 2 if x = 1 then seconds=60 if x = 2 then seconds=30 If hs.devicevalue(269) <> 1 then hs.speak "The alarm has detected entry and the siren will activate in less than "& cstr(seconds) & " seconds.",true,"*:*" hs.waitsecs 1 hs.speak "Proceed to nearest keypad and enter your code.",true,"*:*" hs.waitsecs 1 end if If hs.devicevalue(269) <> 1 then hs.speak "The home's perimeter video system recorded your approach and entry, that recording is now in the cloud.",true,"*:*" hs.waitsecs 1 end if if hs.devicevalue(269) <> 1 then hs.speak "Upon siren activation the police will be notified and these recordings will be provided.",true,"*:*" hs.waitsecs 1 end if next if hs.devicevalue(269) <> 1 then hs.speak "Siren activation imminent.",true,"*:*" end if end if hs.writelog "Alarm Tripped","The Script has completed." end sub
-Rick
Rick,
you probably don't even need a loop based on what you are doing.
you could probably just create a function that accepts 'seconds' as an input and then call the routine twice
dostuff(30)
dostuff(60)
sub dostuff(seconds as integer)
end subMark
HS3 Pro 4.2.19.5
