Error initialising when HS restarts ...
I use your plugin for monitoring temperatures.
If HSPro decides to restart, the com port always fails to initialise.
I have to unplug the rs232 lead, restart the actual PC, start homeseer, and only after it has sucessfully initiated the com port for mcstemperature, can i plug in the rs232 and all works fine, until HSPro restarts again!
Any idea how i can get round this, or at least be able to avoid a physical reboot?
I use the Quasar temp kit, and a blackbox 4 port rs232-usb hub.
Thank You.
P.S. The error i het in HS in "Error opening com port" then something about it being in use.
Thank You.
