Go Back   HomeSeer Message Board > Wireless Receiver & Transceiver Plug-ins > Wireless Receiver & Transceiver Discussion > RFXCOM Plug-In (3P)
RFXCOM Plug-In (3P) Discussion area for the RFXCOM 3rd party plug-in.
Old March 11th, 2014, 05:33 AM
Moskus's Avatar
Moskus Moskus is offline
New rain gauge
So my second Oregon Scientific rain gauge bites the dust. And I can't seem to get hold of them anymore.
However, RFXtrx433 supports LaCrosse now. I have no clue about LaCrosse rain gauges, but perhaps others have! All I know is that my fathers rain gauge (LaCrosse) had much better resolution (0,2 mm) than mine (1,0 mm).
Any recommendations?
HSPro 3.0.0.435, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Old March 11th, 2014, 07:42 AM
b_weijenberg b_weijenberg is offline
The LaCrosse is not (yet) implemented in the plug-in.
The LaCrosse rain sensor does not transmit a rain rate value.
It does also not have a total rain counter in the rain sensor but is transmits a flip counter.
If the flip counter is not received (which happens sometimes) the total count is not accurate anymore.
To increase the resolution of the Oregon sensor you can use a funnel to increase the input area by 10 for example.
Spray the internal electronic parts with plastic spray against moisture damage.
If you have opened the rain sensor for this it is a good time to replace the internal antenna with an external one to increase the transmit range. For example this version, remove the SMA and solder the inner wire to the point where the rain sensor coil antenna was connected. The screen of the cable can be soldered to a ground point near the antenna connection.
Old March 11th, 2014, 08:50 AM
Moskus's Avatar
Ah! Did not know that.
The count might be off, but it's better than what I have now which is nothing.
The unit I have now seems to be working 100%, no signals lost or anyting, but it does not register anything when the tip tips...
My first idea was just to replace it. But I can't seem to find it anywhere... ?
Old March 11th, 2014, 09:31 AM
prnorton prnorton is offline
They show to be in stock at the following site:
http://www.oregonscientificstore.com...-Stations.data
}{ Phil }{
Old March 11th, 2014, 09:43 AM
Moskus's Avatar
Do you happen to know if they offer international shipping?
Old March 11th, 2014, 10:09 AM
Sorry, I didn't notice your location. The site above only ships to USA and Canada. The closest one for you I found online was in the UK.
Old March 11th, 2014, 11:28 AM
langenet's Avatar
langenet langenet is offline
Is there a way to integrate this to HS using the ACRF-2 plugin or do I need the RFXCOM plugin. If the later, is there any issue on using both when the ACRF-2 owns the device? I have temp sensors attached to ACRF-2.
Rob
HS3PRO 3.0.0.435 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dot, WS+, WD+ ... on and on.
Old March 11th, 2014, 11:34 AM
I suppose the Oregon rain sensor is supported by the ACRF2
It is not possible to share one receiver by two plug-ins. It is possible to have the ACRF2 connected to an RFXCOM receiver and the RFXCOM plug-in to another RFXCOM receiver.
HTML code is On
Crazy rain gauge kas MCS Temperature 5 September 8th, 2007 08:49 PM
Rain Gauge steve-l MCS Temperature 8 October 31st, 2005 11:49 AM
AAG Rain gauge? sbessel MCS Temperature 27 September 21st, 2004 04:53 PM
AAG rain gauge counter RAM Midon Design Temp05/08 4 April 29th, 2004 04:14 PM
